Wasn't sure how to word this one so I hope you can understand what im on about!
I am updating three tables in two sql server databses by passing values into three relevant methods() in my registration class file. I wont go into too much detail as to how ive ended up with this as it is the result of over coming a mountain of obstacles during this development.
Basicly, I send the relevant values to the relevant methods() and commit the data in the very last method by .ExecuteNonQuery(s), to make sure all data is update at the same time... previously data was getting update as and when, and if an error occured half way through, the data would be inconsistant!
At the moment, values are updated to a table and then if all is OK returns true to continue... I have tried to force an error in my code and in my control(s) values but it does not pick up the error, and so always returns true!
If I add the .ExecuteNonQuery just before the return then it picks up the errors and returns false, but I cannot / dont want to execute there, for the above reasons.
Does anyone know of another way (piece of trickery maybe) to check for errors withoutt using the .ExecuteNonQuery here?
Thanks guys!
public bool RegUser(string fn, string ln, string a1, string a2, string a3, string pCode, string country,
string mNum, string email)
SqlConnection con = new SqlConnection(ConfigurationManager.ConnectionStrings["UserConnectionString"].ConnectionString);
con.Open();
string insCmd = "INSERT INTO UserTable (FirstName, LastName, AddressLine_1, AddressLine_2, AddressLine_3, Postcode, Country, MobileNumber, EmailAddress, Roles, Time, Date) VALUES (@FirstName, @LastName, @AddressLine_1, @AddressLine_2, @AddressLine_3, @Postcode, @Country, @MobileNumber, @EmailAddress, @Roles, @Time, @Date)";
insertUser = new SqlCommand(insCmd, con);
insertUser.Parameters.AddWithValue("@FirstName", fn);
insertUser.Parameters.AddWithValue("@LastName", ln);
insertUser.Parameters.AddWithValue("@AddressLine_1", a1);
insertUser.Parameters.AddWithValue("@AddressLine_2", a2);
insertUser.Parameters.AddWithValue("@AddressLine_3", a3);
insertUser.Parameters.AddWithValue("@Postcode", pCode);
insertUser.Parameters.AddWithValue("@Country", country);
insertUser.Parameters.AddWithValue("@MobileNumber", mNum);
insertUser.Parameters.AddWithValue("@EmailAddress", email);
insertUser.Parameters.AddWithValue("@Roles", "LoggedUser");
insertUser.Parameters.AddWithValue("@Time", DateTime.Now.ToShortTimeString());
insertUser.Parameters.AddWithValue("@Date", DateTime.Today.Date);
try // THIS WILL ALWAYS BE TRUE !!! HOW TO CHECK AND RETURN FALSE IF ERROR OCCURS?
return true;
catch
return false;
public bool RegAuthDetails(string pw, string PIN)
SqlConnection con2 = new SqlConnection(ConfigurationManager.ConnectionStrings["UserConnectionString"].ConnectionString);
con2.Open();
string insCmd = "INSERT INTO UserAuthDetails (Password, PaymentPIN) VALUES (@Password, @PaymentPIN)";
insertUserAuth = new SqlCommand(insCmd, con2);
insertUserAuth.Parameters.AddWithValue("@Password", pw);
insertUserAuth.Parameters.AddWithValue("@PaymentPIN", PIN);
try
return true;
catch
return false;
[code]
public void RegUserBankDetails(bool Mobile, string cardNum, string expiryMM, string expiryYYYY, string cardName, string securityCode,
string email)
SqlConnection con = new SqlConnection(ConfigurationManager.ConnectionStrings["UserBankDatabaseConnectionString"].ConnectionString);
con.Open();
string insCmd = "INSERT INTO UserBankTable (CardNumber, ExpiryDateMM, ExpiryDateYYYY, NameOnCard, SecurityCode, EmailAddress, Time, Date) VALUES (@CardNumber, @ExpiryDateMM, @ExpiryDateYYYY, @NameOnCard, @SecurityCode, @EmailAddress, @Time, @Date)";
insertPayInfo = new SqlCommand(insCmd, con);
insertPayInfo.Parameters.AddWithValue("@CardNumber", cardNum);
insertPayInfo.Parameters.AddWithValue("@ExpiryDateMM", expiryMM);
insertPayInfo.Parameters.AddWithValue("@ExpiryDateYYYY", expiryYYYY);
insertPayInfo.Parameters.AddWithValue("@NameOnCard", cardName);
insertPayInfo.Parameters.AddWithValue("@SecurityCode", securityCode);
insertPayInfo.Parameters.AddWithValue("@EmailAddress", email);
insertPayInfo.Parameters.AddWithValue("@Time", DateTime.Now.ToShortTimeString());
insertPayInfo.Parameters.AddWithValue("@Date", DateTime.Today.Date);
try
insertUser.ExecuteNonQuery();
insertUserAuth.ExecuteNonQuery();
insertPayInfo.ExecuteNonQuery();
con.Close(); // IS THIS CLOSING ALL THREE CONNECTIONS ????
if (Mobile == false)
HttpContext.Current.Response.Redirect("Login.aspx", false); // need to test these bools..!
return;
else if (Mobile == true)
HttpContext.Current.Response.Redirect("MobileLogin.aspx", false); // check this also!!!
return;
catch
HttpContext.Current.Response.Redirect("~/ErrorPages/ErrorPage.aspx", false); // should be true i think ???
return;
HttpContext.Current.Response.Redirect("MobileErrorPages/ErrorPage.aspx", false); // should be true i think ???
return;
