I have an ASP.NET AJAX Tab Container and inside a Tab Panel, I have a simple form consisting of a couple of textboxes. The data is dynamically loaded in to textboxes on pageload. Now When its loaded, the textboxes are basically there for users to update their profile.
Now I have applied 100% correct code (in my opinion, as I've been always using) on the update button. It even calls the method, and initiates the try catch block as well. Even shows in label that data is updated. But the data is not updated actually.
What is this? something about Postback or what? Am just a newbie in ASP.NET - hope someone can quickly help.
						ASP.NET AJAX Tab Container and a Simple C# Update Statement
Re: ASP.NET AJAX Tab Container and a Simple C# Update Statement
That means you have used an INSERT or UPDATE, isn't it?
Have you commit data after writing to DB ?
