This is the real essence of server side language such as ASP.Net, connecting to database, saving from database etc. that's how lot of websites are built, and work with data.
From this code, you can extract the parts that are required for your application.
import System.Data
import System.Data.SqlClient
Function ConnectToDB(byval select_string, byval username as string, byval password as string, byval server as string, byval database as string)
'this is declaring the sqlconnection, the sql command statement and the datareader
Dim connection_ As SqlConnection
Dim sqlcommand_ As SqlCommand
Dim SqlDataReader_ As SqlDataReader 'Here we make the connection, put in the server adresse, login username, password and database
connection_ = New SqlConnection( "server=YOURSERVER; uid=username; pwd=password; database=YOURDATABASE")
'Opening the connection
connection_.Open
cmdLath = New SqlCommand (select_string, connection_)
SqlDataReader_ = cmdLath.ExecuteReader
datareader.DataSource = rdrLath
datareader.DataBind
'Always remember to close your connections, even though many servers auto close or has a timeout closing
SqlDataReader_.Close
sqlcommand_.Dispose
connection_.Close
End function
