A typical MySQL statement should look like this:
mysql_connect("$host", "$dbuser", "$dbpswd") or sql_error("connect",mysql_error());
?>At the top of your script (before any MySQL statements) put the function sql_error:
function sql_error($function,$mysql_err) {
This script can send an email and/or make an entry in a log file
There are two variables below - one for an email address and one for a log file
Set both vraiables to the values you want to use
If you do not want either an email or log entry, comment out the respective line
For example, if you do not want an email sent, put a // in front of the $emailAddress line - same for the $logFile line
$logFile = $_SERVER['DOCUMENT_ROOT'].'/mysql.log'; // full path to your log file - you should create an empty starter file if you use logging
$emailAddress = "[email protected]"; // set to your email address
putenv('TZ=EST5EDT'); // eastern time
// modify the above values to fit your environment
echo "<center><br><hr>
Oops . . . looks like our database is having technical problems.
<br><br>
Please come back later . . . hopefully we can get things up and running again soon.
<hr>";
if (isset($logFile)) {
$logData = "Error: $function - $mysql_err"."||".$_SERVER['HTTP_HOST'].$_SERVER['REQUEST_URI']."||".$_SERVER['REMOTE_ADDR']."||".date('Y-m-d H:i:s')."\r\n";
@file_put_contents($logFile,$logData,FILE_APPEND|LOCK_EX);
if (isset($emailAddress)) {
$error_time = (date(" F d h:ia"));
$message .= "There has been a MySQL error.\n\n";
$message .= "Error: $function - $mysql_err\n\n";
$message .= "Server time of the error: $error_time\n\n";
mail($emailAddress,"MySQL error",$message,"From: Website <>");
die();
