In your html, put an <img> tag for the image, such as the one below. Do not put width or height parameters in the img tag as this will distort the generated image.
<img src="counter.php" alt="counter" style="border: inset 3px;">
You can download this script as a .txt file. Remember to rename the file as a .php file.
$filename = 'counter.dat';
session_start();
if (!isset($_SESSION['visitor_counter']) AND is_writable($filename)) {
$count = @file_get_contents($filename);
if (is_numeric($count)) {
$count++;
@file_put_contents($filename,$count,LOCK_EX);
$_SESSION['visitor_counter'] = $count;
} else {
$count = $_SESSION['visitor_counter'];
$width = (strlen($count)*8)+8;
$im = @imagecreate($width, 18);
$background_color = imagecolorallocate($im,255,255,255);
$text_color = imagecolorallocate($im,0,0,0);
imagestring($im,4,4,2,$count,$text_color);
imagepng($im);
imagedestroy($im);
Put your web page, counter.php and counter.dat in the same directory.
If you want an invisible counter (cannot be seen on the page), you can simply use the following <img> tag in the html page:
<img src="counter.php" alt="" style="display: none;">
If you would like a comma in the number if the number is more than 3 digits, then add this line just before the $width calculation:
if (strlen($count)>3) $count = substr($count,0,strlen($count)-3).",".substr($count,strlen($count)-3,3);
If you are using a PHP page and want to include the counter in a text line rather than display it as an image, as is done at the bottom of this page, you can simply replace the bottom half of the script (everything after the if/else test) with this one line:
echo "You are visitor $count";
Note - If the user's browser is blocking cookies, then the counter will count each page hit rather than browser sessions.
