The file ( or image ) will be first uploaded to a directory and then one thumbnail image will be created in a different directory. So for creating and the thumbnail we will check the file extension ( it is gif or jpeg image ) but to keep the script simple we are not checking here the file size. So if the file size is to be restricted then that validation is to be added. You can see how the file size checking is done in file upload tutorial.
The file ( or image ) will be first uploaded to a directory and then one thumbnail image will be created in a different directory. So for creating the thumbnail we will check the file extension ( it is gif or jpeg image ) but to keep the script simple we are not checking here the file size. So if the file size is to be restricted then file size validation is to be added. You can see how the file size checking is done in file upload tutorial.
This script is tested with PHP 5.2.6 with register_global is OFF. Please update your script if you have downloaded the old version of this.
<form enctype="multipart/form-data" action="addimgck.php" method=post>
Upload this file: <input name="userfile" type="file">
<input type="submit" value="Send File"></form>
// Below lines are to display file name, temp name and file type , you can use them for testing your script only//////
echo "File Name: ".$_FILES[userfile][name]."<br>";
echo "tmp name: ".$_FILES[userfile][tmp_name]."<br>";
echo "File Type: ".$_FILES[userfile][type]."<br>";
echo "<br><br>";
$add="upimg/".$_FILES[userfile][name]; // the path with the file name where the file will be stored, upload is the directory name.
//echo $add;
if(move_uploaded_file ($_FILES[userfile][tmp_name],$add)){
echo "Successfully uploaded the mage";
chmod("$add",0777);
}else{echo "Failed to upload file Contact Site admin to fix the problem";
exit;}
///////// Start the thumbnail generation//////////////
$n_width=100; // Fix the width of the thumb nail images
$n_height=100; // Fix the height of the thumb nail imaage
$tsrc="thimg/".$_FILES[userfile][name]; // Path where thumb nail image will be stored
//echo $tsrc;
if (!($_FILES[userfile][type] =="image/pjpeg" OR $_FILES[userfile][type]=="image/gif")){echo "Your uploaded file must be of JPG or GIF. Other file types are not allowed<BR>";
exit;}
//////////// Starting of GIF thumb nail creation///////////
if (@$_FILES[userfile][type]=="image/gif")
$im=ImageCreateFromGIF($add);
$width=ImageSx($im); // Original picture width is stored
$height=ImageSy($im); // Original picture height is stored
$newimage=imagecreatetruecolor($n_width,$n_height);
imageCopyResized($newimage,$im,0,0,0,0,$n_width,$n_height,$width,$height);
if (function_exists("imagegif")) {
Header("Content-type: image/gif");
ImageGIF($newimage,$tsrc);
elseif (function_exists("imagejpeg")) {
Header("Content-type: image/jpeg");
ImageJPEG($newimage,$tsrc);
chmod("$tsrc",0777);
}////////// end of gif file thumb nail creation//////////
////////////// starting of JPG thumb nail creation//////////
if($_FILES[userfile][type]=="image/pjpeg"){
$im=ImageCreateFromJPEG($add);
ImageJpeg($newimage,$tsrc);
//////////////// End of JPG thumb nail creation //////////
