Can anybody suggest me a cool light weight php ide?
I'm using an old pc [1.0GHz procesor, 384MB RAM, 32MB VGA].
Before I used notepad2 for php works. but i think it's not suitable for me now.
thankz.
Light-Weight PHP IDE
Re: Light-Weight PHP IDE
First thing you need to clarify is whether you need a IDE or a php editor (text editor with syntax highlighting).
If you are looking for a php editor, Notepadd++, Programmers Notepad and UltraEdit are good.
IDE are little bit heaver than editors. I guess you know they integrates syntax checker, code optimizer, debugger, run on the fly like facilities. Most of the phpIDEs come with HTML, CSS- and JavaScript editor as well.
Have a look at this article from IBM. Seven great PHP IDEs compared
Zend Studio
This is the most famous one. This was created by the original authors of php (if my memory is right).
NetBeans IDE
Eclipse PHP IDE - Heavy
Eclipse considered as the best open source IDE in the world.
NuSphere PhpED
Dev-PHP IDE
This is an open source IDE which is worth to give a try.
Zend Studio
NetBeans IDE
NuSphere PhpED
Dev-PHP IDE
I used NotePad2 since the day I told "Hello world" with PHP. It is the collest syntax editor in the world (as I think). Because It loads within a second on any computer and support for number of programing languages with syntax high-lighting.Neo wrote:First thing you need to clarify is whether you need a IDE or a php editor (text editor with syntax highlighting).
But the problem is that, still I can't write php syntax with my own without any spelling mistakes. All of you know, I haven't any proper knowladge in php. Only learnt php with doing practicles. Also I don't like to read books wich have thousands of pages.
Now I'm going work on a somewhat complex project. So I thought "a PHP IDE will help me on the project". Anyway I'll give a try with above IDEs and reply with results.
Thank you.
Rksk, Higher education (after A/Ls) is all about reading books. So you will have to get used to itAlso I don't like to read books wich have thousands of pages.
Anyway, after A/Ls, don't forget to have some fun. Because you will have to go in to stressful lifestyle as a software engineer and you won't get that freedom again.
Those are not IDEs. Those just text editors with php syntax highlighting. IDEs must have built-in debugger, syntax suggestion like features which you won't find in a text editor. Also, if you are serious about php, I recommend you to start with Zend Studio or Eclipse. Both are very professional IDEs.Anyway I'll give a try with above IDEs and reply with results.
I told about the IDEs you suggested.Neo wrote:Those are not IDEs. Those just text editors with php syntax highlighting. IDEs must have built-in debugger, syntax suggestion like features which you won't find in a text editor. Also, if you are serious about php, I recommend you to start with Zend Studio or Eclipse. Both are very professional IDEs.Anyway I'll give a try with above IDEs and reply with results.
I only wanted syntax suggetion function. Because it will very easy to code.
Anyway, it seems those IDEs aren't suitable for my pc. So I'll stay with my old friend Notepad2.
OFF TOPIC
I like it.Neo wrote:Anyway, after A/Ls, don't forget to have some fun. Because you will have to go in to stressful lifestyle as a software engineer and you won't get that freedom again.
I have to run my brother's small electronic workshop after A/L. So i wont get any freedom.
Also I haven't much sure on A/L, because the Maths paper was a disaster. (It was too easy, but I unabled to answer it correctly, i don't know what happen in the exam hall).
Anyway I successed at the Physics paper. Chemistry is on tommorrow.
