int preg_match (string $pattern, string $subject [, array &$matches [, int $flags = 0 [, int $offset = 0 ]]] )
- Find a String in a String
Find a string in a string can be done very easily by preg_match. Let’s have a look at the following two examples.
The “i” after the pattern delimiter indicates a case-insensitive searchOutputCode: Select all
/* Case Sensitive Search */ if ( preg_match("/cool/", "I love to share Cool things that help others. @lifeobject1") ) { echo "A match was found."; } else { echo "A match was not found."; } echo "<br />"; /* Case Insensitive Search */ if ( preg_match("/cool/i", "I love to share Cool things that help others. @lifeobject1") ) { echo "A match was found."; } else { echo "A match was not found."; }
A match was not found. A match was found.
- Find a Word in a String
Find a word in a string is a hot and regular requirement in the php development. PHP beautifully provides this solution and we will achieve this task by the following two examples of preg_match.
The “\b” in the pattern indicates a word boundary, so only the distinctOutputCode: Select all
/* Word "profession" is matched, and not a word partial like "professional" or "professionalism" */ if ( preg_match("/\bprofession\b/i", "I am Software Engineer by profession. @lifeobject1") ) { echo "A match was found."; } else { echo "A match was not found."; } echo "<br />"; /* Word "profession" is matched, and not a word partial like "professional" or "professionalism" */ if ( preg_match("/\bprofession\b/i", "My professional ethic is sharing. @lifeobject1") ) { echo "A match was found."; } else { echo "A match was not found."; }
A match was found. A match was not found.
- Find Domain Name from URL
PHP developers often require to find a domain name from URL. preg_match provides a very easy solution. Let’s have a look into following examples.
If matches is provided, then it is filled with the results of search. $matches[0] will contain the text that matched the full pattern, $matches[1] will have the text that matched the first captured parenthesized subpattern, and so on.OutputCode: Select all
/* Get host name from URL */ preg_match( '@^(?:http://)?([^/]+)@i', "https://robot.lk/category/php/", $matches ); $host = $matches[1]; echo "Host name is: " . $host; echo "<br />"; /* Get last two segments of host name */ preg_match('/[^.]+\.[^.]+$/', $host, $matches); echo "Domain name is: " . $matches[0];
Host name is: robot.lk Domain name is: robot.lk
- Valid IP Address Check
preg_match makes the validity of IP address very easy. Let’s have a look into the following method which returns the validity of IP address professionally.
Do not use preg_match() if you only want to check if one string is contained in another string. Use strpos() or strstr() instead as they will be faster.OutputCode: Select all
/* Valid IP Method */ function get_valid_ip( $ip ) { return preg_match("/^([1-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])" . "(\.([0-9]|[1-9][0-9]|1[0-9][0-9]|2[0-4][0-9]|25[0-5])){3}$/", $ip ); } /* Valid IP Example */ $ip = "192.168.0.5"; if ( get_valid_ip( $ip ) ) { echo $ip . " is valid."; } echo "<br />"; /* Invalid IP Example */ $ip = "256.157.0.5"; if ( ! get_valid_ip( $ip ) ) { echo $ip . " is not valid."; }
192.168.0.5 is valid. 256.157.0.5 is not valid.
- US Phone Number Format Example
Getting a US phone number format is a tough task as user may input phone number in different formats. Let’s have a look at the power of preg_match. You will notice a usage of preg_replace for the sake of getting US phone number format.OutputCode: Select all
/* US Phone Number Format Regex */ $regex = '/^(?:1(?:[. -])?)?(?:\((?=\d{3}\)))?([2-9]\d{2})' .'(?:(?<=\(\d{3})\))? ?(?:(?<=\d{3})[.-])?([2-9]\d{2})' .'[. -]?(\d{4})(?: (?i:ext)\.? ?(\d{1,5}))?$/'; /* Different Formats */ $formats = array( '520-628-4539', '520.628.4539', '5206284539' , '520 628 4539', '(520)628-4539', '(520) 628-4539', '(520) 628 4539', '520-628.4539', '520 628-4539', '(520)6284539', '520.628-4539', '15206284539', '1 520 628 4539', '1.520.628.4539', '1-520-628-4539', '520-628-4539 ext.123', '520.628.4539 EXT 123 ', '5206284539 Ext. 5889', '520 628 4539 ext 8', '(520) 628-4539 ext. 456', '1(520)628-4539'); /* Let's Format Them */ foreach( $formats as $phoneNumber ) { if( preg_match($regex, $phoneNumber) ) { echo "Phone Number Matched " . $phoneNumber . " - US Format: " . preg_replace($regex, '($1) $2-$3 ext. $4', $phoneNumber); echo "<br />"; } }
Phone Number Matched 520-628-4539 - US Format: (520) 628-4539 ext. Phone Number Matched 520.628.4539 - US Format: (520) 628-4539 ext. Phone Number Matched 5206284539 - US Format: (520) 628-4539 ext. Phone Number Matched 520 628 4539 - US Format: (520) 628-4539 ext. Phone Number Matched (520)628-4539 - US Format: (520) 628-4539 ext. Phone Number Matched (520) 628-4539 - US Format: (520) 628-4539 ext. Phone Number Matched (520) 628 4539 - US Format: (520) 628-4539 ext. Phone Number Matched 520-628.4539 - US Format: (520) 628-4539 ext. Phone Number Matched 520 628-4539 - US Format: (520) 628-4539 ext. Phone Number Matched (520)6284539 - US Format: (520) 628-4539 ext. Phone Number Matched 520.628-4539 - US Format: (520) 628-4539 ext. Phone Number Matched 15206284539 - US Format: (520) 628-4539 ext. Phone Number Matched 1 520 628 4539 - US Format: (520) 628-4539 ext. Phone Number Matched 1.520.628.4539 - US Format: (520) 628-4539 ext. Phone Number Matched 1-520-628-4539 - US Format: (520) 628-4539 ext. Phone Number Matched 520-628-4539 ext.123 - US Format: (520) 628-4539 ext. 123 Phone Number Matched 5206284539 Ext. 5889 - US Format: (520) 628-4539 ext. 588 Phone Number Matched 520 628 4539 ext 8 - US Format: (520) 628-4539 ext. 8 Phone Number Matched (520) 628-4539 ext. 456 - US Format: (520) 628-4539 ext. 456 Phone Number Matched 1(520)628-4539 - US Format: (520) 628-4539 ext.
- Valid Email Address Regex
Email address validation is a regular requirement of PHP developers. Let’s see at following example.
Because making a truly correct email validation function is harder than one may think, consider using with pure PHP through the filter_var function.Code: Select all
/* Valid Email Address Regex */ function get_valid_email( $email ) { $regex = '/^([*+!.&#$¦\'\\%\/0-9a-z^_`{}=?~:-]+)@(([0-9a-z-]+\.)+[0-9a-z]{2,4})$/i'; return preg_match($regex, trim($email), $matches); } /* Different Emails */ $emails = array( '[email protected]', '[email protected]', 'cool@yahoo', 'kholi.net', '[email protected]', '[email protected]', 'gem@yahoo.',); /* Let's Check Them */ foreach( $emails as $email ) { if( get_valid_email( $email ) ) { echo "Valid Email: " . $email; } else { echo "Invalid Email: " . $email; } echo "<br />"; }
OutputOut of the Box: Email Address Validation with PHP filter_var functionCode: Select all
Valid Email: [email protected] Valid Email: [email protected] Invalid Email: cool@yahoo Invalid Email: kholi.net Valid Email: [email protected] Valid Email: [email protected] Invalid Email: gem@yahoo.
Let’s see at following example of email address validation with PHP through the filter_var function.OutputCode: Select all
/* Valid Email Address filter_var */ function get_valid_email( $email ) { return filter_var( $email, FILTER_VALIDATE_EMAIL ); } /* Different Emails */ $emails = array( '[email protected]', '[email protected]', 'cool@yahoo', 'kholi.net', '[email protected]', '[email protected]', 'gem@yahoo.',); /* Let's Check Them */ foreach( $emails as $email ) { if( get_valid_email( $email ) ) { echo "Valid Email: " . $email; } else { echo "Invalid Email: " . $email; } echo "<br />"; }
- Validate URL Regular Expression
We can use preg_match for the validation of any type of URL. Let’s have a look into the code snippet of PHP URL Validation.OutputCode: Select all
/* Validate URL Regular Expression */ function get_valid_url( $url ) { $regex = "((https?|ftp)\:\/\/)?"; // Scheme $regex .= "([a-z0-9+!*(),;?&=\$_.-]+(\:[a-z0-9+!*(),;?&=\$_.-]+)?@)?"; // User and Pass $regex .= "([a-z0-9-.]*)\.([a-z]{2,3})"; // Host or IP $regex .= "(\:[0-9]{2,5})?"; // Port $regex .= "(\/([a-z0-9+\$_-]\.?)+)*\/?"; // Path $regex .= "(\?[a-z+&\$_.-][a-z0-9;:@&%=+\/\$_.-]*)?"; // GET Query $regex .= "(#[a-z_.-][a-z0-9+\$_.-]*)?"; // Anchor return preg_match("/^$regex$/", $url); } /* Different URLs */ $urls = array( 'https://robot.lk/', 'https://robot.lk/viewtopic.php?f=41&t=2619', 'http://www.google.com/#sclient=psy&hl=en&source=hp&q=robotlk&aq=f&aqi=&aql=&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=97eede9ed711c932&biw=1920&bih=895', 'ftp://some.domaon.com/', 'wwwwelcomecom', 'tcp://www.domain.com', 'http://wordpress.org', 'https:www.secure.net', 'https://.com', 'https://www.lock.com', 'https://robot.lk'); /* Let's Check Them */ foreach( $urls as $url ) { if( get_valid_url( $url ) ) { echo "Valid URL: " . $url; } else { echo "Invalid URL: " . $url; } echo "<br />"; }
Valid URL: https://robot.lk/ Valid URL: https://robot.lk/viewtopic.php?f=41&t=2619 Valid URL: http://www.google.com/#sclient=psy&hl=en&source=hp&q=robotlk&aq=f&aqi=&aql=&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=97eede9ed711c932&biw=1920&bih=895 Valid URL: ftp://some.domaon.com/ Invalid URL: wwwwelcomecom Invalid URL: tcp://www.domain.org Valid URL: http://wordpress.org Invalid URL: https:www.secure.net Valid URL: https://.com Valid URL: https://www.lock.com Valid URL: https://robot.lk
