- __LINE__
The current line number of the file. - __FILE__
The full path and filename of the file. If used inside an include, the name of the included file is returned. Since PHP 4.0.2, __FILE__ always contains an absolute path with symlinks resolved whereas in older versions it contained relative path under some circumstances. - __DIR__
The directory of the file. If used inside an include, the directory of the included file is returned. This is equivalent to dirname(__FILE__). This directory name does not have a trailing slash unless it is the root directory. (Added in PHP 5.3.0.) - __FUNCTION__
The function name. (Added in PHP 4.3.0) As of PHP 5 this constant returns the function name as it was declared (case-sensitive). In PHP 4 its value is always lowercased. - __CLASS__
The class name. (Added in PHP 4.3.0) As of PHP 5 this constant returns the class name as it was declared (case-sensitive). In PHP 4 its value is always lowercased. - __METHOD__
The class method name. (Added in PHP 5.0.0) The method name is returned as it was declared (case-sensitive). - __NAMESPACE__
The name of the current namespace (case-sensitive). This constant is defined in compile-time (Added in PHP 5.3.0).
What are PHP Magic Constants
- karnti4545
Re: What are PHP Magic Constants
used jequry Library In php Constants but Normal used javascript.
Thank
Thank
