* Change the path to your folder.
* This must be the full path from the root of your
* web space. If you're not sure what it is, ask your host.
* Name this file index.php and place in the directory.
// Define the full path to your folder from root
$path = "/home/user/public/foldername/";
// Open the folder
$dir_handle = @opendir($path) or die("Unable to open $path");
// Loop through the files
while ($file = readdir($dir_handle)) {
if($file == "." || $file == ".." || $file == "index.php" )
continue;
echo "<a href=\"$file\">$file</a><br />";
// Close
closedir($dir_handle);
