ini_set('display_errors', 1);
error_reporting(E_ALL);
$ky = 'lkirwf897+22#bbtrm8814z5qq=498j5'; // 32 * 8 = 256 bit key
$iv = '741952hheeyy66#cs!9hjv887mxx7@8y'; // 32 * 8 = 256 bit iv
$text = "Here is my data to encrypt!!!";
$from_vb = "QBlgcQ2+v3wd8RLjhtu07ZBd8aQWjPMfTc/73TPzlyA="; // enter value from vb.net app here to test
$etext = encryptRJ256($ky, $iv, $text);
$dtext = decryptRJ256($ky, $iv, $etext);
$vtext = decryptRJ256($ky, $iv, $from_vb);
echo "<HR>orignal string: $text";
echo "<HR>encrypted in php: $etext";
echo "<HR>decrypted in php: $dtext";
echo "<HR>encrypted in vb: $from_vb";
echo "<HR>from vb decrypted in php: $vtext";
echo "<HR>If you like it say thanks! richard dot varno at gmail dot com";
exit;
function decryptRJ256($key,$iv,$string_to_decrypt)
$string_to_decrypt = base64_decode($string_to_decrypt);
$rtn = mcrypt_decrypt(MCRYPT_RIJNDAEL_256, $key, $string_to_decrypt, MCRYPT_MODE_CBC, $iv);
$rtn = rtrim($rtn, "\0\4");
return($rtn);
function encryptRJ256($key,$iv,$string_to_encrypt)
$rtn = mcrypt_encrypt(MCRYPT_RIJNDAEL_256, $key, $string_to_encrypt, MCRYPT_MODE_CBC, $iv);
$rtn = base64_encode($rtn);
return($rtn);
VB.Net Code
Imports System
Imports System.Text
Imports System.Security.Cryptography
Imports System.IO
Module Module1
Sub Main()
'Shared 256 bit Key and IV here
Dim sKy As String = "lkirwf897+22#bbtrm8814z5qq=498j5" '32 chr shared ascii string (32 * 8 = 256 bit)
Dim sIV As String = "741952hheeyy66#cs!9hjv887mxx7@8y" '32 chr shared ascii string (32 * 8 = 256 bit)
Dim sTextVal As String = "Here is my data to encrypt!!!"
Dim eText As String
Dim dText As String
eText = EncryptRJ256(sKy, sIV, sTextVal)
dText = DecryptRJ256(sKy, sIV, eText)
Console.WriteLine("key: " & sKy)
Console.WriteLine()
Console.WriteLine(" iv: " & sIV)
Console.WriteLine("txt: " & sTextVal)
Console.WriteLine("encrypted: " & eText)
Console.WriteLine("decrypted: " & dText)
Console.WriteLine("If you like it say thanks! richard dot varno at gmail dot com")
Console.WriteLine("press any key to exit")
Console.ReadKey(True)
End Sub
Public Function DecryptRJ256(ByVal prm_key As String, ByVal prm_iv As String, ByVal prm_text_to_decrypt As String)
Dim sEncryptedString As String = prm_text_to_decrypt
Dim myRijndael As New RijndaelManaged
myRijndael.Padding = PaddingMode.Zeros
myRijndael.Mode = CipherMode.CBC
myRijndael.KeySize = 256
myRijndael.BlockSize = 256
Dim key() As Byte
Dim IV() As Byte
key = System.Text.Encoding.ASCII.GetBytes(prm_key)
IV = System.Text.Encoding.ASCII.GetBytes(prm_iv)
Dim decryptor As ICryptoTransform = myRijndael.CreateDecryptor(key, IV)
Dim sEncrypted As Byte() = Convert.FromBase64String(sEncryptedString)
Dim fromEncrypt() As Byte = New Byte(sEncrypted.Length) {}
Dim msDecrypt As New MemoryStream(sEncrypted)
Dim csDecrypt As New CryptoStream(msDecrypt, decryptor, CryptoStreamMode.Read)
csDecrypt.Read(fromEncrypt, 0, fromEncrypt.Length)
Return (System.Text.Encoding.ASCII.GetString(fromEncrypt))
End Function
Public Function EncryptRJ256(ByVal prm_key As String, ByVal prm_iv As String, ByVal prm_text_to_encrypt As String)
Dim sToEncrypt As String = prm_text_to_encrypt
Dim encrypted() As Byte
Dim toEncrypt() As Byte
Dim key() As Byte
Dim IV() As Byte
Dim encryptor As ICryptoTransform = myRijndael.CreateEncryptor(key, IV)
Dim msEncrypt As New MemoryStream()
Dim csEncrypt As New CryptoStream(msEncrypt, encryptor, CryptoStreamMode.Write)
toEncrypt = System.Text.Encoding.ASCII.GetBytes(sToEncrypt)
csEncrypt.Write(toEncrypt, 0, toEncrypt.Length)
csEncrypt.FlushFinalBlock()
encrypted = msEncrypt.ToArray()
Return (Convert.ToBase64String(encrypted))
End Function
End Module
