How to get live currency rates using PHP
Post by Saman » Tue Dec 21, 2010 2:29 pm
In this method, we used to get live currency rates from Google. This function uses curl so make sure you have enabled curl extension in php.
<?php
function currency($from_Currency, $to_Currency, $amount) {
    $amount = urlencode($amount);
    $from_Currency = urlencode($from_Currency);
    $to_Currency = urlencode($to_Currency);
    $url = "http://www.google.com/ig/calculator?q=$amount$from_Currency=?$to_Currency";
    $ch = curl_init();
    $timeout = 0;
    curl_setopt ($ch, CURLOPT_URL, $url);
    curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
    curl_setopt ($ch, CURLOPT_USERAGENT , "Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1)");
    curl_setopt ($ch, CURLOPT_CONNECTTIMEOUT, $timeout);
    $rawdata = curl_exec($ch);
    curl_close($ch);
    $data = explode('"', $rawdata);
    $data = explode(' ', $data[3]);
    $var = $data[0];
    return round($var,4);
Usage:
echo currency('GBP', 'USD', 1);
Re: How to get live currency rates using PHP
Post by Saman » Tue Aug 02, 2011 9:19 pm
Google has changed the protocol. Here is the new code.
<?php
function get_currency($from_Currency, $to_Currency, $amount) {
	$url = "http://www.google.com/finance/converter?a=$amount&from=$from_Currency&to=$to_Currency";
	$ch = curl_init();
	$timeout = 0;
	curl_setopt ($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1)");
	curl_close($ch);
	$data = explode('bld>', $rawdata);
	$data = explode($to_Currency, $data[1]);
	return round($data[0], 2);
Post by Rksk » Tue Aug 02, 2011 10:18 pm
Thankz. REP+
Hikkurs
Post by Hikkurs » Mon Dec 12, 2011 11:12 pm
Can I implement this code into my WP based blog? Where should I put it? TIA
Post by Saman » Wed Dec 14, 2011 7:31 pm
Sorry for my delayed reply.
Yes you can add this to any php based code. I can't tell you where exactly you need to put that since it is solely depend on your requirement. If you don't know php, you can get someone to work it out for you.
asifqwq
Contact:
Post by asifqwq » Wed Jan 04, 2012 12:22 pm
A really nice idea. I appreciate it much !
jaheen100
Corporal
Corporal
Post by jaheen100 » Thu Jan 09, 2014 4:04 pm
You can get easily live currency rates at http://www.forextrading.pk/open-market- ... -rates.php . This site will help You to check currency rates and give other information about the open market.
Post by Saman » Fri Jan 10, 2014 11:57 am
Where is the php code? Programmers here needs that, not a site :)
Return to “PHP & MySQL”
