function compress_css($file, $urls)
$code = @file_get_contents($file);
// replace urls
$code = str_replace('url(' . $urls, 'url(', $code);
// remove comments
$code = clean($code, 'css');
return $code;
function compress_js($file)
// remove comments
$code = clean($code, 'js');
return $code;
function clean($code, $type)
$start = 0;
$lines = explode("\n", $code);
// remove "//" type comments
for($i=0; $i<count($lines); $i++)
if(($pos = strpos($lines[$i], '//')) !== false)
// check if its in string
$prev = $pos > 0 ? substr($lines[$i], 0, $pos) : '';
$count = substr_count($prev, "'") - substr_count($prev, "\\'");
if(($count % 2) == 1) continue;
$count = substr_count($prev, '"') - substr_count($prev, '\\"');
$lines[$i] = $pos > 0 ? substr($lines[$i], 0, $pos) : '';
// trim lines
$lines[$i] = trim($lines[$i]);
$code = implode("\n", $lines);
// remove /* */ comments
$start = 0;
while(($pos = strpos($code, '/*', $start)) !== false)
$pos2 = strpos($code, '*/', $start);
$code = substr($code, 0, $pos) . ($pos2 === false ? '' : substr($code, $pos2 + 2));
$start = $pos2 === false ? strlen($code) : $pos;
// remove spaces
if($type == 'js')
$code = str_replace(array("\t", "\n", "\r", ' '), array(' ', '', '', ' '), $code);
while(strpos($code, ' ') !== false)
$code = str_replace(' ', ' ', $code);
else
// css stuff
if($type == 'css')
$code = str_replace(array('} ', ' }', ' {', '{ ', ': ', '; '), array('}', '}', '{', '{', ':', ';'), $code);
return $code;
echo compress_css('whatever.css', ''); // reads whatever.css and outputs compressed code
echo compress_js('whatever.js'); // reads whatever.js and outputs compressed code
- It isn't designed to handle css hacks that are using comments, such as /*\*//*/
- It removes comments even if they are inside a string, so make sure you don't have strings like str = "/* blah */" (same applies to double spaces and tabs. use "\t" if you want a tab)
- In javascript files make sure you have ; after } where its needed. Example of code that would normally be parsed, but it won't be parsed in compressed format:
$.fn.whatever = function() { }
$.fn.test = function() {}
$.fn.whatever = function() { };
$.fn.test = function() {};
