How copy a mysql database to another server
howto copy a mysql db to another db on another server with all data using php ?
Re: How copy a mysql database to another server
There are many options for this.
- You can have two connections to both databases and iterate through all tables and copy records.
Here you can either copy each record using a loop or use something similar as below.
mysql_query("SELECT * INTO OUTFILE 'temp.sql' FROM my_table", $conn1);
mysql_query("LOAD DATA INFILE 'temp.sql' INTO TABLE my_table", $conn2); - If you have phpMyAdmin, you can use Export from source and and use Import at destination end.
- You can easily use mysqldump to backup your database to a file and then restore it using command "mysql" at destination end.
i want to backup my db daily with freemysql.net
can you give an eample in php?
thankz
thankz
See tutorials in that website. All required information are there. If you can't find anything, just ask them. ROBOT.LK can't support on 3rd party products.
Regards...
Regards...
Thankz.
freemysql.net is only a mysql server.
I agree. It's all well explained there. Read through http://www.freemysql.net/v2/tutorials/p ... part-1.php.Saman wrote:See tutorials in that website. All required information are there. If you can't find anything, just ask them. ROBOT.LK can't support on 3rd party products.
Regards...
Both of you have forgot one thing.Saman & Neo wrote:ROBOT.LK can't support on 3rd party products.
if you don't support on 3rd party producs, you will can't help us to use any software , ect.
don't care, a joke only.
thankz.
3rd Party products means the products that are made using other products. Usually our topics are made for the original products.Both of you have forgot one thing.
For example the product you have added which was build on MySQL. Our topic is MySQL/SQL and Database concepts.
It is usual to have a complete help on site for such products/packages. It is unlikely that you get help for these kind of products from ROBOT.LK as no one is willing to install those on their machines.
