write data to a file wich received from GET
Post by Rksk » Wed Jun 02, 2010 4:17 pm
I use this script to Write data to a file wich sent from GET method.
But it doen't write datas with sent as 2nd time.
it writes data the file at only 1st time.
if (isset($_GET['t'])) {
if (!file_exists("list.html"))
  $myFile = "list.html";
  $fh = fopen($myFile, 'w');
  $stringData = "\n";
  fwrite($fh, $stringData);
  fclose($fh);
$myFile2 = "list.html";
$fh2 = fopen($myFile2, 'a');
$stringData2 = $_GET['t']."<br> \n <br><p>";
fwrite($fh2, $stringData2);
fclose($fh2);
echo "\n complete";
what is the bug? i'm having a trouble with it!
Re: write data to a file wich received from GET
Post by Neo » Wed Jun 02, 2010 4:57 pm
fopen ( filename , 'a' ) will create a file if not exists. So first thing is you don't need to have the first part to create a file if it is not exists with 'w'. Just remove it and see whether it works.
To see how many bytes the fwrite has written, you may use echo fwrite(.......);
Post by Rksk » Wed Jun 02, 2010 5:20 pm
Thakz neo.
it's working
Return to “PHP & MySQL”
