There are several ways determine a file extension using PHP. First is using the combination of strrpos() and substr() function like this :
$ext = substr($fileName, strrpos($fileName, '.') + 1);
For example, if $fileName is my-new-house.jpg then strrpos($fileName, '.') will return the last location a dot character in $fileName which is 15. So substr($fileName, strrpos($fileName, '.') + 1) equals to substr($fileName, 16) which return 'jpg'
The second is using strrchr() and substr() :
$ext = substr(strrchr($fileName, '.'), 1);
strrchr($fileName) returns '.jpg' so substr(strrchr($fileName, '.'), 1) equals to substr('.jpg', 1) which returns 'jpg'
