What You’ll Learn
- How to use cURL to get the content from a website (URL)
- Call PHP DOM functions to parse the HTML so you can extract links
- Use XPath to grab links from specific parts of a page
- Store the scraped links in a MySQL database
- Put it all together into a link scraper
- What else you could use a scraper for
- Legal issues associated with scraping content
- Basic knowledge of PHP and MySQL
- A web server running PHP 5
- The cURL extension for PHP
- MySQL – if you want to store the links
Get The Page Content
cURL is a great tool for making requests to remote servers in PHP. It can imitate a browser in pretty much every way. Here’s the code to grab our target site content:
$ch = curl_init();
curl_setopt($ch, CURLOPT_USERAGENT, $userAgent);
curl_setopt($ch, CURLOPT_URL,$target_url);
curl_setopt($ch, CURLOPT_FAILONERROR, true);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
curl_setopt($ch, CURLOPT_AUTOREFERER, true);
curl_setopt($ch, CURLOPT_RETURNTRANSFER,true);
curl_setopt($ch, CURLOPT_TIMEOUT, 10);
$html = curl_exec($ch);
if (!$html) {
echo "<br />cURL error number:" .curl_errno($ch);
echo "<br />cURL error:" . curl_error($ch);
exit;
Tip: Fake Your User Agent
Many websites won’t play nice with you if you come knocking with the wrong User Agent string. What’s a User Agent string? It’s part of every request to a web server that tells it what type of agent (browser, spider, etc) is requesting the content. Some websites will give you different content depending on the user agent, so you might want to experiment. You do this in cURL with a call to curl_setopt() with CURLOPT_USERAGENT as the option:
$userAgent = 'Googlebot/2.1 (http://www.googlebot.com/bot.html)';
Common User Agents
I’ve done a bit of the leg work for you and gathered the most common user agents:
Search Engine User Agents
- Google – Googlebot/2.1 ( http://www.googlebot.com/bot.html)
- Google Image – Googlebot-Image/1.0 ( http://www.googlebot.com/bot.html)
- MSN Live – msnbot-Products/1.0 (+http://search.msn.com/msnbot.htm)
- Yahoo – Mozilla/5.0 (compatible; Yahoo! Slurp; http://help.yahoo.com/help/us/ysearch/slurp)
- ask
- Firefox (WindowsXP) – Mozilla/5.0 (Windows; U; Windows NT 5.1; en-GB; rv:1.8.1.6) Gecko/20070725 Firefox/2.0.0.6
- IE 7 – Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30)
- IE 6 – Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR 1.1.4322)
- Safari – Mozilla/5.0 (Macintosh; U; Intel Mac OS X; en) AppleWebKit/522.11 (KHTML, like Gecko) Safari/3.0.2
- Opera – Opera/9.00 (Windows NT 5.1; U; en)
Using PHP’s DOM Functions To Parse The HTML
PHP provides with a really cool tool for working with HTML content: DOM Functions. The DOM Functions allow you to parse HTML (or XML) into an object structure (or DOM – Document Object Model). Let’s see how we do it:
$dom = new DOMDocument();
@$dom->loadHTML($html);
Tip: You may have noticed I put @ in front of loadHTML(), this suppresses some annoying warnings that the HTML parser throws on many pages that have non-standard compliant code.
XPath Makes Getting The Links You Want Easy
Now for the real magic of the DOM: XPath! XPath allows you to gather collections of DOM nodes (otherwise known as tags in HTML). Say you want to only get links that are within unordered lists. All you have to do is write a query like “/html/body//ul//li//a” and pass it to XPath->evaluate(). I’m not going to go into all the ways you can use XPath because I’m just learning myself and someone else has already made a great list of examples: XPath Examples. Here’s a code snippet that will just get every link on the page using XPath:
$xpath = new DOMXPath($dom);
$hrefs = $xpath->evaluate("/html/body//a");
Iterate And Store Your Links
Next we’ll iterate through all the links we’ve gathered using XPath and store them in a database. First the code to iterate through the links:
for ($i = 0; $i < $hrefs->length; $i++) {
$href = $hrefs->item($i);
$url = $href->getAttribute('href');
storeLink($url,$target_url);
We’ll want a database table that looks something like this:
CREATE TABLE `links` (
`url` TEXT NOT NULL ,
`gathered_from` TEXT NOT NULL ,
`time_stamp` TIMESTAMP NOT NULL
function storeLink($url,$gathered_from) {
$query = "INSERT INTO links (url, gathered_from) VALUES ('$url', '$gathered_from')";
mysql_query($query) or die('Error, insert query failed');
Your Completed Link Scraper
$target_url = "https://robot.lk/";
// make the cURL request to $target_url
$ch = curl_init();
$html= curl_exec($ch);
if (!$html) {
exit;
// parse the html into a DOMDocument
// grab all the on the page
echo "<br />Link stored: $url";
What Else Could I Do With This Thing?
The possibilities are limitless. For starters you might want to store a list of sites that you want scraped in a database and then set up the script so it runs on a regular basis to scrap those sites. You could then compare the link structure over time or maybe republish the links in some sort of directory. Leave a comment below and say what you’re using this script for. Here are a few other things people have done with scrapers in the past:
- Build a search engine from the content you gather. Ex: Google
- Analyze a site to determine how well it is SEO optomized for keywords. SEO Book’s Keyword Density Tool.
- Republish free content dynamically on your website.
- Create an RSS feed from a website. See Using PHP To Scrape Web Sites As Feeds
Is Scraping Content Legal?
There is no easy answer to this question. Many organizations scrap content from all over the web – Google, Yahoo, Microsoft, and many others. These companies get away with it under fair use and because site owners want to be included in the search results. However, there have been copyright infringement rulings against these companies.
The real answer is that it depends who you scrape and what you do with the content. Basic copyright law gives authors an automatic copyright on everything they create. But the same law permits fair use of copyrighted material. Fair use includes: criticism, comment, news reporting, teaching (including multiple copies for classroom use), scholarship, or research. But even these uses could be considered copyright infringement in some circumstances. So be careful before you claim “fair use” as your defense!
Here’s a couple sites that have granted you the right to use their content. They do require you to attribute the content to the author or the URL you scraped it from:
- Wikipedia – GNU Free Documentation License
- Open Directory Project – Open Directory License
- Creative Commons – Creative Commons Attribution 3.0
Many sites publish their content under some form of the Creative Commons license. You can search for creative commons licensed works here: Creative Commons Search. Remember that it’s your responsibility to verify the copyright rules for anything you use, even stuff found using the Creative Commons Search.
