How to fetch Twitter feed (including retweets) in php
Post by Neo » Sun Feb 28, 2010 11:04 pm
Here is a PHP that fetches a Twitter stream for a specified user. It also combines retweets with the regular updates. This puts them all in an array to make it easy to output them however you want.
This snippet uses APC to cache the data, but you can use any caching method such as memcached or database. It should be fairly easy to edit in your own caching.
$tw_user = ''; // Twitter username
$tw_pass = ''; // Twitter password
$tw_key = 'twitter'; // Unique key to cache tweets
$tw_count = 5; // Number of tweets to get
$tw_timeout = 300; // How long to cache tweets in seconds
$updates = apc_fetch($tw_key);
if(!$updates) {
   $timelines = array();
   $tw_auth = $tw_user . ':' . $tw_pass;
   $timeline_url = 'http://twitter.com/statuses/user_timeline.xml?count=' . $tw_count . '&screen_name=' . $tw_user;
   $retweet_url = 'https://api.twitter.com/1/statuses/retweeted_by_me.xml?count=' . $tw_count;
   // Get regular tweets
   $curl = curl_init();
   curl_setopt($curl, CURLOPT_URL, $timeline_url);
   curl_setopt($curl, CURLOPT_RETURNTRANSFER, true);
   $timelines[] = curl_exec($curl);
   curl_close($curl);
   // Get retweets
   curl_setopt($curl, CURLOPT_URL, $retweet_url);
   curl_setopt($curl, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
   curl_setopt($curl, CURLOPT_USERPWD, $tw_auth);
   curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
   curl_close($curl);
   $updates = array();
   // Set up replace patterns
   $patterns = array('#(http\://[^\s]*)#i',
               '/@([a-z1-9_]+)/i',
               '/(#[a-z1-9_]+)/i');
   $replace = array('<a href="$1" target="_blank">$1</a>',
               '@<a href="http://twitter.com/$1" target=_blank">$1</a>',
               '<a href="http://twitter.com/search?q=$1" target=_blank">$1</a>');
   foreach($timelines as $timeline) {
      $xmlDoc = DOMDocument::loadXML($timeline);
      $statuses = $xmlDoc->getElementsByTagName('status');
      if($statuses->length > 0) {
         foreach($statuses as $status) {
            $id = intval($status->getElementsByTagName('id')->item(0)->nodeValue);
            $text = $status->getElementsByTagName('text')->item(0)->nodeValue;
            $date = strtotime($status->getElementsByTagName('created_at')->item(0)->nodeValue);
            $text = preg_replace($patterns, $replace, $text); // Parse links
            $updates[$id] = array($text, $date);
   krsort($updates); // Sort tweets by id
   $updates = array_slice($updates, 0, $tw_count); // Limit tweet count
   apc_store($tw_key, $updates, $tw_timeout); // Cache data
Return to “PHP & MySQL”
