if(){
//first make sure that no other file with that name exists
if(!file_exists($xmldoc)){
//try to open the file
if($fp=fopen($xmldoc,'w+')){
//write to the file
fwrite($fp,"<?xml version=1.0 ?><br>");
//set the root element i.e: <rootelementname>
fwrite($fp,”<articles>);
fwrite($fp,"<article>\n");
//Now we set the child elements
//Title
fwrite($fp,'<title>The Amazing truth</title>\n’);
//Set te Author name
fwrite($fp,'<auth>John Doe</auth>\n");
//Set the date
fwrite($fp,'<date>2008-11-12</date>\n");
//Set the description
fwrite($fp,'<description>Some long description here</description>\n’);
//close child element
fwrite($fp,"</article>");
//Now close the root element
fwrite($fp,"</articles>");
//close the file
fclose($fp);
Our document is going to be called contacts.xml; it will be updated via our database also called contacts, which contains a table called contact. First, we create the database table. We want the table to have the following fields:
- name – name of the contact
- email – email address of the contact
- address- address of contact
CREATE TABLE `contact` (
`id` int(4) NOT NULL auto_increment,
`name` varchar(50) NOT NULL,
`email` varchar(50) NOT NULL,
`address` text NOT NULL,
PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=4 DEFAULT CHARSET=latin1 AUTO_INCREMENT=4 ;
# Dumping data for table `contact`
INSERT INTO `contact` VALUES (1, 'eno', '[email protected]', '12 ghd');
INSERT INTO `contact` VALUES (2, 'simon', '/[email protected]', '78 Panny Road');
INSERT INTO `contact` VALUES (3, 'Xuro', '[email protected]', '368 Lann Road');
<?xml version="1.0" ?>
<contacts>
<contact>
<name></name>
<email></email>
<address></address>
</contact>
</contacts>
menu.php:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Untitled Document</title>
</head>
<body>
<table width="100%" border="1">
<tr>
<td bgcolor="#CCCCCC"><h1 align="center">XML Document Proccessor </h1></td>
</tr>
<tr>
<td> </td>
</tr>
<tr>
<td><a href="form.php">Create New XML Document </a></td>
</tr>
<tr>
<td><a href="inputform.php">Add new XML data to Database </a></td>
</tr>
<tr>
<td><a href="write2xmldoc.php">Create Updated XML document </a></td>
</tr>
<tr>
<td> </td>
</tr>
</table>
</body>
</html>
//create file
if(isset($_POST['submit'])){
//initialise vars
$msg = "";
//make sure that all the form fields are filled in
if(empty($_POST['name'])){
$msg = "Please enter a <b>Name</b> for the contact<br>";
if(empty($_POST['email'])){
$msg .= "Please enter a <b>Email Address</b> for the contact<br>";
if(empty($_POST['address'])){
$msg .= "Please enter a <b>Address</b> for the contact<br>";
if(empty($msg)){
//1. Store the information in the database
$q = "INSERT INTO contact (id,name,email,address) values (".$_POST['name'].",".$_POST['email'].",".$_POST['address'].")";
$r = mysql_query($q);
if($r){
$msg = "Contact has been added to the database";
}else{
$msg = "The following error occurred:<br>" mysql_error();
}//end submit check
<head>
</head>
<body>
<form id="form1" name="form1" method="post" action="">
<tr>
<td colspan="2" bgcolor="#CCCCCC">Contacts Information Input Form </td>
</tr>
<tr>
<td> </td>
<td> </td>
</tr>
<tr>
<td width="12%"><strong>Name:</strong></td>
<td width="88%"><label>
<input name="name" type="text" id="name" />
</label></td>
</tr>
<tr>
<td><strong>Email:</strong></td>
<td><label>
<input name="email" type="text" id="email" />
</label></td>
</tr>
<tr>
<td><strong>Address:</strong></td>
<td><label>
<textarea name="address" id="address"></textarea>
</label></td>
</tr>
<tr>
<td> </td>
<td><label>
<input name="submit" type="submit" id="submit" value="Save Contact Information" />
</label></td>
</tr>
</table>
</form>
</body>
</html>
//create file
//initialise vars
$msg = "";
if(empty($_POST['fn'])){
$msg = "Please enter a file name<br>";
if(empty($_POST['rootEl'])){
$msg .= "Please enter a <b>root element</b> name<br>";
if(empty($_POST['title'])){
$msg .= "Please enter a <b>Title</b><br>";
if(empty($_POST['auth'])){
$msg .= "Please enter a <b>Author</b> name<br>";
if(empty($_POST['desc'])){
$msg .= "Please enter a <b>Description</b>";
if(empty($msg)){
//set the name of the file
$xmldoc = $_POST['fn'].".xml";
//write to the file
fwrite($fp,"<?xml version='1.0' ?>");
fwrite($fp,'<'.$_POST['rootEl'].'>');
//Title
fwrite($fp,'<title>'.$_POST['title']."</title>\n");
fwrite($fp,'<auth>'.$_POST['auth']."</auth>\n");
//Set the date
fwrite($fp,'<date>'.$_POST['dte']."</date>\n");
fwrite($fp,'<description>'.$_POST['desc']."</description>\n");
fwrite($fp,"</".$_POST['rootEl'].">");
//close the file
fclose($fp);
//inform user that the writing was a success
$msg = "The XML document called ".$xmldoc. " has been created";
}else{
$msg = "There was an error, could not create the XML document.";
}else{
$msg = "File name already exists, please try again";
}//err check
}//submit
<head>
<style type="text/css">
.style1 {
color: #FF0000;
font-weight: bold;
</style>
</head>
<body>
<form action="" method="post">
<tr>
<td colspan="2" bgcolor="#CCCCCC"><h1 align="center">XML and PHP </h1></td>
</tr>
<tr>
<td colspan="2" valign="top"><?php if(isset($msg)){
echo "<span class='style1'>".$msg."</span>";
</td>
</tr>
<tr>
<td valign="top">New XML document name: </td>
<td><label>
<input name="fn" type="text" id="fn" />
</label></td>
</tr>
<tr valign="top">
<td colspan="2" bgcolor="#CCCCCC"><strong>Root Element: </strong></td>
</tr>
<tr>
<td valign="top">Root Element Name: </td>
<td><label>
<input name="rootEl" type="text" id="rootEl" value="articles"/>
</label></td>
</tr>
<tr>
<td colspan="2" valign="top" bgcolor="#CCCCCC"><strong>Child Elements: </strong></td>
</tr>
<tr>
<td valign="top">Title</td>
<td><label>
<input name="title" type="text" id="title" value="The Amazing Truth"/>
</label></td>
</tr>
<tr>
<td valign="top">Author</td>
<td><label>
<input name="auth" type="text" id="auth" value="Axaro !Noabeb"/>
</label></td>
</tr>
<tr>
<td valign="top">Date</td>
<td>
<label>
<input type="text" name="dte" value="<?php echo date("Y-m-d")?>"/>
</label></td>
</tr>
<tr>
<td valign="top">Description</td>
<td><label>
<textarea name="desc" cols="25" rows="5" id="desc">Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Donec molestie. Sed aliquam sem ut arcu. Phasellus sollicitudin. Vestibulum condimentum facilisis nulla. In hac habitasse platea dictumst. Nulla nonummy. Cras quis libero. Cras venenatis. Aliquam posuere lobortis pede. Nullam fringilla urna id leo. Praesent aliquet pretium erat. Praesent non odio. Pellentesque a magna a mauris vulputate lacinia. Aenean viverra. Class aptent taciti sociosqu ad litora torquent per conubia nostra, per inceptos hymenaeos. Aliquam lacus. Mauris magna eros, semper a, tempor et, rutrum et, tortor. </textarea>
</label></td>
</tr>
<tr>
<td> </td>
<td><label>
<input name="submit" type="submit" id="submit" value="Create XML Document" />
</label></td>
</tr>
</table>
</form>
</body>
</html>
$xmldoc = "myxml.xml";
//write to the file
fwrite($fp,"<contacts>");
//connect to database server
$host ="localhost";
$pw ="pass";
$user = "root";
$dbname = "contacts";
$dbc=mysql_connect($host,$user,$pw) or die(mysql_error());
mysql_select_db($dbname) or die(mysql_error());
$q = "SELECT * FROM contact";
if($r){
while($row = mysql_fetch_assoc($r)){
fwrite($fp,"<contact>\n");
//Name of contact
fwrite($fp,'<name>'.$row['name']."</name>\n");
//Set the email address of contact
fwrite($fp,'<email>'.$row['email']."</email>\n");
//Set the address of the contact
fwrite($fp,'<address>'.$row['address']."</address>\n");
fwrite($fp,"</contact>");
}//while
fwrite($fp,"</contacts>");
//close the file
fclose($fp);
}else{
$msg = "Error occurred ".mysql_error();
}// if $r
$msg = "The XML document called ".$xmldoc. " has been created.<br>To view the updated XML document click <a href=".$xmldoc.">here</a>";
}else{
}else{
<head>
.style1 {
color: #FF0000;
font-weight: bold;
</style>
</head>
<body>
</body>
</html>
