How to set file permission using php
Post by Neo » Thu Feb 11, 2010 10:47 am
Permissions are set using a command called CHMOD. CHMOD stands for CHange MODe. You are giving the host computer new instructions about this file or directory.
Syntax: bool chmod ( string $filename , int $mode )
CHMOD comes as a set of 3 numbers. Each of these 3 numbers is a sum total of 3 other numbers. So you have to add 3 numbers to get the first CHMOD number, add 3 numbers to get the second CHMOD number and add 3 numbers to get the third CHMOD number.
Understanding the numbers...
Each digit is a number value from 0 to 7. The value specifies what capabilities are available (or not). These numbers correspond to 3 command types. Read, write and execute.
Read (r) has a value of 4. It allows listing files in the directory.
Write (w) has a value of 2. It allows the addition of new files to the directory.
Execute (x) has a value of 1. It allows access to the files in the directory.
Here are the possible combinations available using these command types:
DigitrwxResult
0---no access
1--xexecute
2-w-write
3-wxwrite and execute
4r--read
5r-xread and execute
6rw-read and write
7rwxread write execute
OK... so you know each digit will be a number from 0 to 7, but what does the 3 digits stand for?
The first number represents the host server. This will usually be set to 7 giving the host full permission on the files in the folder. The second number represents the group (YOU - the individual being hosted). And the third number represents the world (the visitors to the site). Normally, on free hosts, these two digits will be set to 4, allowing the reading (and displaying) of files. Thus, no executing capabilities.
Typical settings for files are 777, 755, 666 or 644.
Typical settings for directories are 777 or 755.
CGI scripts 755, data files 666, and configuration files 644.
Make sure that you give the mode as an octal number. i.e.: 0777 (not just 777)
Example:
    $fp = fopen("myfile.txt", 'r');
    if(!$fp) {
        /* Must be 0444 (octal), NOT just 444 */
        if(!chmod("myfile.txt", 0444)) {
            echo "Error -- couldn't open myfile.txt for reading!";
            exit;
        } else {
    $myvalue = fgets($fp, 1024);
    fclose($fp);
The code to set mode of all files within a directory:
function chmodr($path, $filemode) {
    if (!is_dir($path))
        return chmod($path, $filemode);
    $dh = opendir($path);
    while (($file = readdir($dh)) !== false) {
        if($file != '.' && $file != '..') {
            $fullpath = $path.'/'.$file;
            if(is_link($fullpath))
                return FALSE;
            elseif(!is_dir($fullpath) && !chmod($fullpath, $filemode))
                    return FALSE;
            elseif(!chmodr($fullpath, $filemode))
                return FALSE;
    closedir($dh);
    if(chmod($path, $filemode))
        return TRUE;
    else
        return FALSE;
Return to “PHP & MySQL”
