// | SimpleCloak |
// | Class for cloaking content |
// | http://www.SEOEgghead.com |
// | Copyright (c) 2005-2006 Jaimie Sirovich and Cristian Darie |
// load configuration file
require_once('config.inc.php');
class SimpleCloak
// returns the confidence level
function isSpider($spider_name = '', $check_uas = true, $check_ips = true)
// default confidence level to 0
$confidence = 0;
// matching user agent?
if ($check_uas)
if (SimpleCloak::_get(0, $spider_name, 'UA', $_SERVER['HTTP_USER_AGENT']))
$confidence += 2;
// matching IP?
if ($check_ips)
if (SimpleCloak::_get(0, $spider_name, 'IP', '', $_SERVER['REMOTE_ADDR']))
$confidence += 3;
// return confidence level
return $confidence;
// retrieve cloaking data filtered by the supplied parameters
function _get($id = 0, $spider_name = '', $record_type = '',
$value = '', $wildcard_value = '')
// by default, retrieve all records
$q = " SELECT cloak_data.* FROM cloak_data WHERE TRUE ";
// add filters
if ($id) {
$id = (int) $id;
$q .= " AND id = $id ";
if ($spider_name) {
$spider_name = mysql_escape_string($spider_name);
$q .= " AND spider_name = '$spider_name' ";
if ($record_type) {
$record_type = mysql_escape_string($record_type);
$q .= " AND record_type = '$record_type' ";
if ($value) {
$value = mysql_escape_string($value);
$q .= " AND value = '$value' ";
if ($wildcard_value) {
$wildcard_value = mysql_escape_string($wildcard_value);
$q .= " AND ( '$wildcard_value' = value OR '$wildcard_value' LIKE CONCAT(value, '.%') ) ";
// Connect to MySQL server
$dbLink = mysql_connect(DB_HOST, DB_USER, DB_PASSWORD)
or die("Could not connect: " . mysql_error());
// Connect to the seophp database
mysql_select_db(DB_DATABASE) or die("Could not select database");
// execute the query
$tmp = mysql_query($q);
// close database connection
mysql_close($dbLink);
// return the results as an associative array
$rows = array();
while ($_x = mysql_fetch_assoc($tmp)) {
$rows[] = $_x;
return $rows;
// updates the entire database with fresh spider data, but only if our data is
// more than 7 days old, and if the online version from iplists.org has changed
function updateAll()
// retrieve last update information from database
$q = "SELECT cloak_update.* FROM cloak_update";
$updated = mysql_fetch_assoc($tmp);
$db_version = $updated['version'];
$updated_on = $updated ['updated_on'];
// get the latest update more recent than 7 days, don't attempt an update
if (isset($updated_on) &&
(strtotime($updated_on) > strtotime("-604800 seconds")))
// return false to indicate an update wasn't performed
return false;
// read the latest iplists version
$version_url = 'http://www.iplists.com/nw/version.php';
$latest_version = mysql_escape_string(file_get_contents($version_url));
// if no updated version information was retrieved, abort
if (!$latest_version)
return false;
// save the update data
$q = "DELETE FROM cloak_update";
mysql_query($q);
$q = "INSERT INTO cloak_update (version, updated_on) " .
"VALUES('$latest_version', NOW())";
mysql_query($q);
// if we already have the current data, don't attempt an update
if ($latest_version == $db_version)
return false;
// update the database
SimpleCloak::_updateCloakingDB('google', 'http://www.iplists.com/nw/google.txt');
SimpleCloak::_updateCloakingDB('yahoo', 'http://www.iplists.com/nw/inktomi.txt');
SimpleCloak::_updateCloakingDB('msn', 'http://www.iplists.com/nw/msn.txt');
SimpleCloak::_updateCloakingDB('ask', 'http://www.iplists.com/nw/askjeeves.txt');
SimpleCloak::_updateCloakingDB('altavista', 'http://www.iplists.com/nw/altavista.txt');
SimpleCloak::_updateCloakingDB('lycos', 'http://www.iplists.com/nw/lycos.txt');
SimpleCloak::_updateCloakingDB('wisenut', 'http://www.iplists.com/nw/wisenut.txt');
// close connection
// return true to indicate a successful update
return true;
// update the database for the mentioned spider, by reading the provided URL
function _updateCloakingDB($spider_name, $url,
$ua_regex = '/^# UA "(.*)"$/m', $ip_regex = '/^([0-9.]+)$/m')
// use cURL to read the data from $url
// NOTE: additional settings are required when accessing the web through a proxy
$ch = curl_init();
curl_setopt ($ch, CURLOPT_URL, $url);
curl_setopt ($ch, CURLOPT_HEADER, 1);
curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt ($ch, CURLOPT_FOLLOWLOCATION, 1);
curl_setopt ($ch, CURLOPT_TIMEOUT, 60);
$result = curl_exec($ch);
curl_close($ch);
// use _parseListURL to parse the list of IPs and user agents
$lists = SimpleCloak::_parseListURL($result, $ua_regex, $ip_regex);
// if the user agents and IPs weren't retrieved, we cancel the update
if (!$lists['ua_list'] || !$lists['ip_list']) return;
// lock the cloack_data table to avoid concurrency problems
mysql_query('LOCK TABLES cloak_data WRITE');
// delete all the existing data for $spider_name
SimpleCloak::_deleteSpiderData($spider_name);
// insert the list of user agents for the spider
foreach ($lists['ua_list'] as $ua) {
SimpleCloak::_insertSpiderData($spider_name, 'UA', $ua);
// insert the list of IPs for the spider
foreach ($lists['ip_list'] as $ip) {
SimpleCloak::_insertSpiderData($spider_name, 'IP', $ip);
// release the table lock
mysql_query('UNLOCK TABLES');
// helper function used to parse lists of user agents and IPs
function _parseListURL($data, $ua_regex, $ip_regex)
$ua_list_ret = preg_match_all($ua_regex, $data, $ua_list);
$ip_list_ret = preg_match_all($ip_regex, $data, $ip_list);
return array('ua_list' => $ua_list[1], 'ip_list' => $ip_list[1]);
// inserts a new row of data to the cloaking table
function _insertSpiderData($spider_name, $record_type, $value)
// escape input data
// build and execute the INSERT query
$q = "INSERT INTO cloak_data (spider_name, record_type, value) " .
"VALUES ('$spider_name', '$record_type', '$value')";
mysql_query($q);
// delete the cloaking data for the mentioned spider
function _deleteSpiderData($spider_name)
// build and execute the DELETE query
$q = "DELETE FROM cloak_data WHERE spider_name='$spider_name'";
mysql_query($q);
