So, you want to send automated email messages from your PHP application. This can be in direct response to a user's action, such as signing up for your site, or a recurring event at a set time, such as a monthly newsletter. Sometimes email contains file attachments, both plain text and HTML portions, and so on. To understand how to send each variation that may exist on an email, we will start with the simple example and move to the more complicated.
- Sending a Simple Text Email
- Sending HTML Email
- Sending Email with Attachments
At first let's consider how to send a simple text email messages. PHP includes the mail() function for sending email, which takes three basic and two optional parameters. These parameters are, in order, the email address to send to, the subject of the email, the message to be sent, additional headers you want to include and finally an additional parameter to the Sendmail program. The mail() function returns True if the message is sent successfully and False otherwise. Have a look at the example:
<?php
//define the receiver of the email
$to = '[email protected]';
//define the subject of the email
$subject = 'Test email';
//define the message to be sent. Each line should be separated with \n
$message = "Hello World!\n\nThis is my first mail.";
//define the headers we want passed. Note that they are separated with \r\n
$headers = "From: [email protected]\r\nReply-To: [email protected]";
//send the email
$mail_sent = @mail( $to, $subject, $message, $headers );
//if the message is sent successfully print "Mail sent". Otherwise print "Mail failed"
echo $mail_sent ? "Mail sent" : "Mail failed";
?>Sending HTML Email
The next step is to examine how to send HTML email. However, some mail clients cannot understand HTML emails. Therefore it is best to send any HTML email using a multipart construction, where one part contains a plain-text version of the email and the other part is HTML. If your customers have HTML email turned off, they will still get a nice email, even if they don't get all of the HTML markup. Have a look at the example:
<?php
$subject = 'Test HTML email';
//create a boundary string. It must be unique
//so we use the MD5 algorithm to generate a random hash
$random_hash = md5(date('r', time()));
//add boundary string and mime type specification
$headers .= "\r\nContent-Type: multipart/alternative; boundary=\"PHP-alt-".$random_hash."\"";
//define the body of the message.
ob_start(); //Turn on output buffering
--PHP-alt-<?php echo $random_hash; ?>
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Hello World!!!
This is simple text email message.
Content-Type: text/html; charset="iso-8859-1"
<h2>Hello World!</h2>
<p>This is something with <b>HTML</b> formatting.</p>
--PHP-alt-<?php echo $random_hash; ?>--
//copy current buffer contents into $message variable and delete current output buffer
$message = ob_get_clean();
//send the email
?>Sending Email with Attachment
The last variation that we will consider is email with attachments. To send an email with attachment we need to use the multipart/mixed MIME type that specifies that mixed types will be included in the email. Moreover, we want to use multipart/alternative MIME type to send both plain-text and HTML version of the email. Have a look at the example:
<?php
$subject = 'Test email with attachment';
$headers .= "\r\nContent-Type: multipart/mixed; boundary=\"PHP-mixed-".$random_hash."\"";
//read the atachment file contents into a string,
//encode it with MIME base64,
//and split it into smaller chunks
$attachment = chunk_split(base64_encode(file_get_contents('attachment.zip')));
--PHP-mixed-<?php echo $random_hash; ?>
Content-Type: multipart/alternative; boundary="PHP-alt-<?php echo $random_hash; ?>"
Hello World!!!
Content-Type: application/zip; name="attachment.zip"
Content-Transfer-Encoding: base64
Content-Disposition: attachment
<?php echo $attachment; ?>
--PHP-mixed-<?php echo $random_hash; ?>--
<?php
//send the email
?>As you can see, sending an email with attachment is easy to accomplish. In the preceding example we have multipart/mixed MIME type, and inside it we have multipart/alternative MIME type that specifies two versions of the email. To include an attachment to our message, we read the data from the specified file into a string, encode it with base64, split it in smaller chunks to make sure that it matches the MIME specifications and then include it as an attachment.
