Important Notes
- Make sure to escape any user-supplied input before passing it to these functions. This is accomplished using the escapeshellcmd() and escapeshellarg() functions, which are explained below. This is very important for security reasons.
- With safe_mode enabled, commands are automatically escaped with escapeshellcmd(). Also, shell_exec() and the "backtick operator" are disabled with safe_mode.
- With safe_mode enabled, only files within the safe_mode_exec_dir can be executed.
- If you use these functions to start a program, PHP will hang until the program ends unless you redirect the output of the program.
- Use escapeshellcmd() to escape all special characters the can be used in the command line. Use this on any user supplied or potentially dangerous input before using it as part of a command on the shell. This will prevent people from tricking the script into running extra commands.
- Use escapeshellarg() to escape a string to be used as a shell argument. This adds single quotes around the string and escapes any unpaired single quotes. This turns any string into a safe shell argument.
The shell_exec() function is the most basic way to run commands from PHP. It accepts the command as the single argument and returns the entire output as a string. It behaves exactly like the "backtick operator" (``).
string shell_exec ( string $cmd )
$output = `cmd`
- cmd: the shell command as a string
- Returns: the output from the shell as a string
- You want to simply run the command and see/store the entire output
The system() function is also a simple way to access the command line. It accepts the command as the first argument and a variable to store the return status of the program as an optional second argument. It only returns the last line if the output.
string system ( string $command [, int &$return_var ] )
- command: the shell command as a string
- return_var: optional; a variable to store the return status of the command
- Returns: the last line of output from the shell as a string
- You want to simply run the command and optionally
- You want to know the return value
- You only need to see the last line of the output
The passthru() function is similar to the system() function, but passes the output from the command directly to the client browser. This is useful when the program produces binary data such as an image.
void passthru ( string $command [, int &$return_var ] )
- You want to run a program and pass binary output directly to the browser
The exec() function provides the most control out of these. It takes the command in the first argument and stores the output and return value in the optional second and third arguments respectively.
string exec ( string $command [, array &$output [, int &$return_var ]] )
- output: optional; a variable to store the output as an array of lines
- You want to simply run a program and optionally
- You want to have access the the full output and/or return status
- You also want easy access to the last line of output
The two functions you really need to know are exec() and passthru(), since these two allow you to do everything that the other functions can do combined. You need to keep security in mind when using these since direct access to the system command line opens up many possibilities. Using the two escape functions will protect you from attacks or unexpected results. Also, keep in mind that safe_mode affects the behaviour of these functions (see the notes above for details).
