Gateway of last resort is not set
C 1.0.0.0/8 is directly connected, serial0/1
C 3.0.0.0/8 is directly connected, serial0/0
C 192.168.1.0/24 is directly connected, loopback0
Configure RIP on Router A
RouterA#configure terminal
RouterA#(config)#router rip
RouterA#(config-router)#network 3.0.0.0
RouterA#(config-router)#network 1.0.0.0
RouterA#(config-router)#network 192.168.1.0
RouterA#(config-router)#exit
RouterA#(config)#
Now verify these configuration on router A with command us under:
RouterA#show ip route
To check the routing protocol with this command.
RouterA#show ip protocols
RouterB#show ip route
C 2.0.0.0/8 is directly connected, serial0/0
Configure RIP on Router B
RouterB#configure terminal
RouterB#(config)#router rip
RouterB#(config-router)#network 1.0.0.0
RouterB#(config-router)#network 2.0.0.0
RouterB#(config-router)#network 192.168.2.0
RouterB#(config-router)#exit
RouterB#(config)#
Now verify these configuration on router B with command us under:
RouterC#show ip route
C 2.0.0.0/8 is directly connected, serial1
C 192.168.3.0/24 is directly connected, loopback0
Configure RIP on Router C
RouterC#configure terminal
RouterC#(config)#router rip
RouterC#(config-router)#network 2.0.0.0
RouterC#(config-router)#network 3.0.0.0
RouterC#(config-router)#network 192.168.3.0
RouterC#(config-router)#exit
RouterC#(config)#
Now verify these configuration on router C with command us under:
Routing Information Protocol (RIP) Configuration
Re: Routing Information Protocol (RIP) Configuration
From your information i understand the Rip routing thanks for that.
I don't know how the load balancing is done in the Rip routing. If you know please help me to understand this topic. Or can we done the load balancing between the two unequal cost link with the Rip routing??
And Thanks in Advance.........
Please have a look at How Does Load Balancing Work?
