Pseudo code Standard
Data structures & algorithms topics
Re: Pseudo code Standard
Post by Neo » Wed Mar 24, 2010 2:26 pm
We must always encourage people to write something their own first. Doesn't matter it is incorrect. Here is a simple pseudo code. See whether you can improve it. There is a little advance algorithm technique called recursion. You might try to use here as well.
number  = raw_input("Please enter an integer: ")
itemCount = 0
maxNum = number
IF (number != 0) THEN  // != is used to denote "not equals"
    WHILE (number != 4)     // && is used to conditional AND operator
        print (number + ", ")
        IF (number & 1) THEN   // odd number (Note & is used to bitwise AND operation)
            number = number * 3 + 1
        ELSE
            number = number / 2
        END IF
        IF (maxNum < number) THEN  // Set max number
            maxNum = number
        END IF
        itemCount = itemCount + 1
    ENDWHILE
    println (number + ", 2, 1")    // println is used to print on a new line
    println ("Total items " + itemCount)
    println ("Largest Number in Sequence " + maxNum)
ELSE
    println ("Invalid number entry")
END IF
See whether this helps!
Post by Face » Wed Mar 24, 2010 4:56 pm
thanks BUDDY.....!!!!!!
for every thing done...
Return to “Data Structures & Algorithms”
