Edit user form (need a help)
Web programming topics
viddz
Sergeant Major
Sergeant Major
Post by viddz » Mon Apr 16, 2012 6:01 pm
Iam new to php and iam having some problems with my edit user php file. The problem is the query doesnt perform. PLs can some one help me with this code. Thanks in advance.
<?php
session_start();
if(!isset($_SESSION['SESS_LOGIN']) || $_SESSION['SESS_TYPE'] !='admin')// if session variable "login" does not exist.
  echo '<script language="javascript">';
  echo  'alert("Please login as ADMINISTRATOR to edit a user");';
  echo	' window.location.replace("login-form.php");';
  echo  '</script>';
//header("location:login-form.php"); // Re-direct to login-form.php
else
      include("config.php");
      $id = mysql_real_escape_string($_POST['id']);
$login    = mysql_real_escape_string($_POST['login']);
$password = mysql_real_escape_string($_POST['password']);
$type     = mysql_real_escape_string($_POST['type']);
$qry_edit = " UPDATE members SET login='$login', password='$password', type='$type' WHERE id='$id' ";
$count = mysql_query("SELECT COUNT(id) FROM members WHERE id='$id'");
		if(mysql_num_rows($count)==1)
		    if($result=mysql_query($qry_edit))
			//or die(mysql_error());
			     /*echo  '<script language="javascript">';
                 echo  'alert("you have successfully edited one user !" );';
                // echo  'window.setTimeout("window.location.replace('adduser.php');",20);';
				 //echo  'window.setTimeout("window.location.replace('adduser.php'),20");';
                 echo  '</script>';*/
			  header("Location: view_all_user.php");
			else
			   echo "<br><font color=red size=+1 >Problem in editing !</font>" ;
			   echo "ERROR - unable to save new username and password!<br>";
               $SQLError =  "SQL ERROR: ".mysql_errno().".  ".mysql_error()."<BR><BR>";
               echo "$SQLError";
               mysql_close();
		//echo "<br><font color=green size=+1 >you have successfully edited one user ! <br>[ username = $login ] </font>" ;
		else
            echo "<br><font color=red size=+1 >No id !</font>" ;
Re: Edit user form (need a help)
Post by Saman » Tue Apr 17, 2012 9:29 pm
It looks like you messed up with string manipulation in php. As a beginner I highly recommend you to use string concatenation with "." operator.
For example, you have used following code:
Change it to:
$qry_edit = "UPDATE members SET login='" . $login "', password='" . $password . "', type='" . $type . "' WHERE id='" . $id . "'";
In this way it is crystal clear on what is happening.
Change your whole code in this way and let us know how it goes.
Good luck!
viddz
Sergeant Major
Sergeant Major
Post by viddz » Thu Apr 19, 2012 9:15 am
Problem was with parsing id. Thanku very much saman :D
Post by Saman » Thu Apr 19, 2012 12:53 pm
You are welcome!
Why don't you add a good Avatar (From User Control Panel), add some information about you such as location, etc... and write a little description about yourself under Member Introductions. So ROBOT.LK can get to know you better.
viddz
Sergeant Major
Sergeant Major
Post by viddz » Fri Apr 20, 2012 9:56 pm
Ha haa haa done. 8-)
Return to “Web programming”
