Start WORD PRESS
Web programming topics
Re: Start WORD PRESS
Post by Neo » Wed Mar 02, 2011 1:41 pm
I just downloaded a press copy of WP and installed on my WAMP. Settings are exactly as yours and it all worked fine without any hesitation. It seems like something restricts access to your DB server.
Can you run the below code and see what you get.
    DB test code written by [email protected] (https://robot.lk)
    02/03/2011
// connect to the mysql server
$link = mysql_connect('localhost', 'root', '');
if (!$link) {
    die ("Could not connect to the MySQL server.<br> Error: ".mysql_error());
// select the database
$db_selected = mysql_select_db('wordpress', $link);
if (!$db_selected) {
    die ("Could not select database.<br> Error: ".mysql_error());
echo "DB Connection Successful";
If you do not get the message "DB Connection Successful" then you will have to check what stops the browser-MySQL connection. This can be a Windows 7 security issue, setting on your firewall/Virus guard, etc... Easiest way is to run this on Windows XP partition to see how it goes.
Post by Nipuna » Wed Mar 02, 2011 2:19 pm
Good to See you Back Neo.
Today Morning I helped G-sparkz to Install WordPress and Now He is Working with It. :)
I think Now your Tight Schedule Might Be Over ;)
Post by Neo » Wed Mar 02, 2011 2:35 pm
This is how the ROBOT.LK members should act :)
No buddy.. Still on it... But I'll try to be with ROBOT.LK as much as possible.
Also, mention the issue on G-sparkZ's WP that you guys have just sorted. This will be helpful for the guys who are looking at this Topic.
Post by Nipuna » Wed Mar 02, 2011 2:55 pm
Thanks Friend
I helped Him Using teamviewer. But Error came again and again.
Then I found the error It was,
G-sparkz was not Running .exe file. He was using the extracted zip file's files.
So i told him to Download the .exe Setup file and then install it and then Run WP under it and It worked.
And He installed and Made Data bases as I told Him.
Then I gave Him the Thesis WordPress theme which need to buy but I downloaded it via a torrent and Gave Him too. ;)
It will give Him More Knowledge too. :)
And Now He is working with it and i think He forgot to Visit ROBOT.LK either because He likes to work with WP. I know so far because He told me he really want to learn WP.
Post by Face » Wed Mar 02, 2011 6:35 pm
Thanks brothers..
NIPUNA helped me lot.We were trting.But the problem waws I got not the exe file but the full compresed file.Nipuna & me tried few times to install We won :)
yeah sure I love to learn Wordpress more & more :)
I will ask more help from you guys...Nipuna We are EXPERTCORE I feel it now :)
* Nice to see you again neo
Kevin
Sergeant Major
Sergeant Major
Post by Kevin » Thu Mar 03, 2011 8:04 pm
Post by Nipuna » Sat Mar 05, 2011 9:08 pm
I've downloaded 2 of Of them
Thanks Friend.
Mysoogal
Post by Mysoogal » Wed Mar 09, 2011 1:52 am
all of windows based LAMP stack servers do not have passwords on them
its always
host: 127.0.0.1
username : root
password: empty
database: whatever you created in phpmyadmin
yup team-viewer is great tool
Ioannes16
Post by Ioannes16 » Mon Mar 14, 2011 6:03 pm
I think that it has a nice integration for the site if you had a good start. It was the factor that they done a good module into the version of WP. And it might be good to assume that we could catch a highest satisfaction for a good start.
Reason: Link removed by admin
stevenmaico
Post by stevenmaico » Wed Mar 28, 2012 3:17 pm
Nice thread for Wordpress discussion and also useful for Wordpress beginners. I hope you will share more information and discussion here.
Return to “Web programming”
