- Open apache’s configuration file using your favorite text editor. The configuration file generally locates at:
If you are using XAMPP or WAMP package then you will find the file at:
{apache_dir}/conf/httpd.conf
{xampp_dir}/apache/conf/httpd.conf {wamp_dir}/apache/conf/httpd.conf
- Search for the following string:
and uncomment it (remove the ‘#’ sign).
#LoadModule rewrite_module modules/mod_rewrite.so
- Now search for another string AllowOverride None and make sure you find it within the section below.
Replace AllowOverride None by AllowOverride All
<Directory /> Options FollowSymLinks AllowOverride None Order deny,allow Deny from all </Directory>
- Finally save the changes, close your text editor and restart your apache server.
How to enable rewrite module in WAMP, XAMPP and Apache
If you are using XAMPP or WAMP, you will find that rewrite module (mod_rewrite) is not enabled by default. Here are the steps to enable it manually.
