All it takes is changing the display CSS property. Setting display: block; (the default for div tags) makes it visible, and display: none; makes it hidden. The advantage to using display is that other items on the page will move to close the void left by the hidden object.
Fist, we'll start with creating the function:
function toggleDisplay(id) {
var obj = document.getElementById(id);
if(obj.style.display == 'none') {
// show the object
} else {
// hide the object
obj.style.display = 'block';
} else {
obj.style.display = 'none';
Now to use it, we just need to call the function with a link, button, or any event. For example:
<div id="div">Test Object</div>
<a href="#" onClick="toggleDisplay('div'); return false;">Show/Hide</a>
Here is the whole example page:
<html>
<head>
<title>Toggle Display</title>
<script type="application/javascript" language="javascript">
} else {
</script>
</head>
<body>
</body>
</html>
