After searching many forums I couldn't find a way to sort this out. Finally I found it was due to a missing setting in 'hosting' table. The path to root folder was missing. I logged in to the psa database and manually entered the path to domain's root folder and it all then executed /usr/local/psa/admin/sbin/websrvmng -a -v to rebuild all apache includes.
All started to work after than. Hope this will help someone.
See How to access Plesk database? if you don't know how to edit Plesk database.
- It is currently Sat May 04, 2024 9:21 pm
How to solve Plesk Internal error: is out of webspace
Linux OS Topics
