- Prep Ubuntu for 32 bit compilation
 Code: Select all sudo apt-get install build-essential lib32z1-dev g++-multilib gcc-multilib ia32-libs libssl1.0.0 libssl1.0.0:i386 libjpeg8 libjpeg8:i386
- Download libpng14 from the following link
Code: Select all http://sourceforge.net/projects/libpng/files/libpng14/1.4.8/libpng-1.4.8.tar.xz/download
- Decompress it by using following command.
Code: Select all tar xvf libpng-1.4.8*
- Now change the folder and compile the source as below.
Note: For 32-bit Linux, remove "CFLAGS=-m32" and just use this line instead:Code: Select all cd libpng-* ./configure CFLAGS=-m32 --prefix=/ make check sudo make installCode: Select all ./configure --prefix=/
- Now install Eagle.
Code: Select all chmod a+x eagle-lin* sudo ./eagle-lin*
How to install Eagle 6.1.0 on Ubuntu 11.10 64-bit
When you try to install Eagle 6.1.0 on Ubuntu 11.10, you will probably get an error message stating that libpng14 is missing. Here is how you could sort that out.
