This was a confusing problem. Whenever I press the Wireless button to enable the wireless network, it stays orange (which should changed to blue if it is enabled). I was told that it could be most probably the wireless driver is hard locked by BIOS, etc... I finally found the solution for this.
Type this command in the command window to change the rfkill state of the wireless chipset.
Enjoy!
