Any one Knows about SCADA HMI Programming
Is there any one , who knows about SCADA HMI Programming?
Re: Any one Knows about SCADA HMI Programming
Several years back I myself involved with few SCADA (Supervisory Control And Data Acquisition) projects. I was involved in HMI (Human-Machine Interface), Supervisory software and RTU (Remote Terminal Units). We used touch screen displays, etc.. The last SCADA project I contributed with VHDL programming was to replace a set of PLSs with FPGAs on a massive mechanical machine.
I mostly involved with programming on both PC and devices where as my uncle (the best electronic engineer I knew in Sri Lanka who can work without any fear but unfortunately he passed away several months ago
) did the electronic integration. If you can describe your requirement, I might be able to help you in programming & designing perspective of the system. Just clarify what you are going to do.
Thank you! for your information.first I want to know what are the tools which use for Programming HMI , is there any special tools ?.
You need to decide your tools. You can use microcontrollers, LCD display with touch control, etc... It is all about designing your system properly to address the machine you are going to control.
