JDM programmer
Nandika
JDM programmer
Post by Nandika » Wed Nov 16, 2011 8:14 pm
i created a jdm programmar according to help with "Vidusara" article in 2007.but,it do not work.i had tried many system.
it pluged to serial port.no response.
plz give me help for program pic16f84a.
you can find "Vidusara" articles from search in google.
help me....
Re: JDM programmer
Post by Rksk » Thu Nov 17, 2011 1:28 am
All those articles are here https://robot.lk/viewtopic.php?f=18&t=1704
Re: JDM programmer
Post by Saman » Thu Nov 17, 2011 12:44 pm
You are the 2nd person who was reporting a problem in a JDM programmer this week. If the circuit diagram is correct and you made everything correctly, it should work. Make sure you have connected the programmer directly to a serial port of the computer. USB -> Serial converters won't work.
See How to start with Microcontrollers article to verify whether you have made the settings correctly.
You can double check with this confirmed working Multi PIC programmer circuit diagram as well. If you are not good in making circuits, I recommend you to buy a off the shelf JDM programmer. We have a member who has started to make PIC programmers now. If you want to buy one, PM me.
Nandika
Re: JDM programmer
Post by Nandika » Fri Nov 18, 2011 9:45 am
Rksk wrote:All those articles are here https://robot.lk/viewtopic.php?f=18&t=1704
i have all vidusara artical.
thank you.
Nandika
Re: JDM programmer
Post by Nandika » Sat Nov 19, 2011 9:10 pm
[quote="Saman"]You are the 2nd person who was reporting a problem in a JDM programmer this week. If the circuit diagram is correct and you made everything correctly, it should work. Make sure you have connected the programmer directly to a serial port of the computer. USB -> Serial converters won't work.
plz give more infomation about your jdm programmar.
Eyenix
Corporal
Corporal
Re: JDM programmer
Post by Eyenix » Mon Nov 21, 2011 12:23 pm
Hi,
Please check the following link....
http://eyenixtech.com/eyenixtech/morein ... programmer
price of this USB programmer is Rs.1900/=..
Call 0779109109 for more information..
Thank You...
Best Regards.....
