i created a jdm programmar according to help with "Vidusara" article in 2007.but,it do not work.i had tried many system.
it pluged to serial port.no response.
plz give me help for program pic16f84a.
you can find "Vidusara" articles from search in google.
help me....
JDM programmer
Re: JDM programmer
All those articles are here https://robot.lk/viewtopic.php?f=18&t=1704
Re: JDM programmer
You are the 2nd person who was reporting a problem in a JDM programmer this week. If the circuit diagram is correct and you made everything correctly, it should work. Make sure you have connected the programmer directly to a serial port of the computer. USB -> Serial converters won't work.
See How to start with Microcontrollers article to verify whether you have made the settings correctly.
You can double check with this confirmed working Multi PIC programmer circuit diagram as well. If you are not good in making circuits, I recommend you to buy a off the shelf JDM programmer. We have a member who has started to make PIC programmers now. If you want to buy one, PM me.
Re: JDM programmer
i have all vidusara artical.Rksk wrote:All those articles are here https://robot.lk/viewtopic.php?f=18&t=1704
thank you.
Re: JDM programmer
[quote="Saman"]You are the 2nd person who was reporting a problem in a JDM programmer this week. If the circuit diagram is correct and you made everything correctly, it should work. Make sure you have connected the programmer directly to a serial port of the computer. USB -> Serial converters won't work.
plz give more infomation about your jdm programmar.
Re: JDM programmer
Hi,
Please check the following link....
http://eyenixtech.com/eyenixtech/morein ... programmer
price of this USB programmer is Rs.1900/=..
Call 0779109109 for more information..
Thank You...
Best Regards.....
Thank You...
Best Regards.....
