Hi,
What's the best way to connect a SD card to a DSP?
I know there are two methods but I couldn't decide what's the best with fewer electronics.
(What are the pros and cons basically?)
Thanks in advance,
Max
Connectng a SD Card to DSP
Re: Connectng a SD Card to DSP
Hi friend ,
There are two methods to speak to SD card from a DSP or from a microcontroller. they are SD mode and SPI mode.
There are two seperate protocoals for both methods. SD mode use 9 pins for communication and SPI mode use only 7.
SD is mode communiation is more fast , but SPI mode is easy implement.
Both the communication protocaols are describe in SD documentation and make sure to see the latest SD documentation
