today i downloaded Windows Live Messenger to chat with one of my friend and then when i log in it says the following error, i searched and i found some trouble shootings but they arnt working
can anyone help me with this issue
Windows Live Messenger Connection error!!
- Moderator
Re: Windows Live Messenger Connection error!!
I received this error few years ago after an upgrade to a later version. I then installed an older version and it worked.
Can you try an older version and see whether it gives you the same error?
- Moderator
i didnt try an old vision, il try and bump this topic
- Moderator
old version is not working too i cant even install it its says i haven't connected to the net
Did you attempt repair options in windows live messenger. Seems like some proxy issue. Try googling the error code. 80072efd
- Moderator
i did, i did every thing that i can possiblely do, still the sameHerath wrote:Did you attempt repair options in windows live messenger. Seems like some proxy issue. Try googling the error code. 80072efd
Can you try this one.
Open a run window by clicking start, then run. Now, type the following command and press enter:
If you use Windows XP you should open another run window after running the previous commands then type the following command:
regsvr32 softpub.dll Wintrust.dll Initpki.dll Rsaenh.dll Mssip32.dll Cryptdlg.dll
regsvr32 Dssenh.dll Gpkcsp.dll Slbcsp.dll Sccbase.dll
- Moderator
this file failed to load and the problem still seems the sameInitpki.dll
and the error msg is "your machine appears to have an invalid ip address" and im using a airtel dongle
I have installed Windows Live Messenger myself to see whether there is any common problem. It worked like a charm So I have noway to simulate the issue. How if you try something like Trilian which supports MSN messenger protocol. Also, I heard you can contact your MSN friends through Yahoo messenger now. But I didn't try it myself.
- Moderator
ya sure il tryNeo wrote:I have installed Windows Live Messenger myself to see whether there is any common problem. It worked like a charm So I have noway to simulate the issue. How if you try something like Trilian which supports MSN messenger protocol. Also, I heard you can contact your MSN friends through Yahoo messenger now. But I didn't try it myself.
