Once I try to install a HSDPA dongle in windows 7, when i run the dongle software the connection didn't work. No errors just didn't connect...
when I run the same program as administrator it worked fine.
So each time when i connect to internet I have to run the program as administrator.......
Any explanations or suggests ??????????????????
Windows 7 Administrator Privileges
Re: Windows 7 Administrator Privileges
It could be due to several reasons. One reason could be the driver you have installed is for Win XP or Vista. May be you would have run the installer as an administrator.
However you can always run this program as the administrator by right click->Compatibility->Put a tick to 'Run this program as an administrator' under 'privilege level'. With this you won't have to remember to run as administrator all the time.
Thanks........... That worked.....Saman wrote:It could be due to several reasons. One reason could be the driver you have installed is for Win XP or Vista. May be you would have run the installer as an administrator.
driver was for xp
I have disabled whole UAC (User Access Control) in Windows 7. I do not want it since I am comfortable with what I am doing with my computer.
