while looking online on another laptop, found the fix
you will need to boot into command prompt from your CD such as windows 7, it provides through the fix my computer,
ok so what now ? when your in cmd, type line by line
and that's about it, next time you reboot, you should see its working normally because the MBR has been rebuilttype in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your coputer
its really stupid that the CD is not able to simply check if the boot.mbr is compressed or not. clicking on fix my computer on the windows 7 CD does not detect anything wrong with the system.
