Blue Screen with Prolink H9601c USB ADSL Modem
Re: Blue Screen with Prolink H9601c USB ADSL Modem
Personally, I like to answer questions with some technical value. For example, programming, embedded, computer science topics such as AI, NN, etc... I'm not much interested with simple stuff like computer maintenance, configuring devices, etc... where a manual or internet help exists already but I like to be a help as much as possible.
Hey Buddy
Is there any 1 port router, that can supply power via USB? Because I don't like to power it Up with AC current because in our aria Power always going.
I can Supply power to it via UPS but I like to know about an USB Power router.
hello is there any router like that?
The USB routers I know needs to be powered up with an external power adapter due to high consumption or power. Though I understand the situation, I don't see a way out other supplying power to router using the system power supply unit. In that way you can avoid the external power adapter.
OK. When I buy one i will use it Via my UPS
this might work
ECIADSL - Howto for USB ADSL Modems http://forum.linuxmint.com/viewtopic.php?f=90&t=12462
its for linux mint 9 but, its same for ubuntu so you can follow it
Thanks Friend I bought a Router and ECIADSL isn't working with New Ubuntu Versions.Mysoogal wrote:this might work
Is the newly bought router support Ethernet connectivity or is it a USB one as before?
It Supports Both Ethernet and USB and I use Ethernet because It doesn't require Drivers to be installed.Neo wrote:Is the newly bought router support Ethernet connectivity or is it a USB one as before?
Exactly.It Supports Both Ethernet and USB and I use Ethernet because It doesn't require Drivers to be installed.
So when you use it over Ethernet on Ubuntu, you only need to set the default gateway with the router's IP. No need to set any other driver.
If you haven't done that already, here is how...
Open /etc/network/interfaces file:
$ sudo vi /etc/network/interfaces
gateway {router-ip}
gateway 192.168.0.5
iface eth0 inet static
address 192.168.0.1
netmask 255.255.255.0
gateway 192.168.0.5
$ sudo /etc/init.d/networking restart
$ ping 192.168.0.5
$ route -n
$ host google.com
