If you are not being able to download MMS coming to your Android phone with a Dialog connection, it is probably that you haven't set the APN settings correctly. Here is how....
Go to*Settings > Wireless & networks > More… > Mobile networks >
Access point names
Press the *Menu* *> New APN*
Enter name: *Dialog**
*APN: *dialogbb*
Proxy: <not set>
Port: <not set>
Username: <not set>
Password: <not set>
Server: <not set>
MMSC: *http://mms.dialog.lk:3130/mmsc*
MMS Proxy: <not set>
MMS Port: *8080*
MCC: *413*
MNC: *02*
Authentication type: *None*
APN type: <not set>
activate the APN. Delete all other APN setting profiles in the list. With this single setting you should be able to browse internet and send/receive MMS.
- It is currently Tue May 07, 2024 12:09 pm
Dialog MMS settings for Android
