type of barcode scanner
What type of barcode scanner do i need? what i'm looking for is a bar-code scanner so i can scan items into memory then put them into the computer to keep track of inventory also quantity would you know what type of bar code scanner i would need and if you need more data let me know
Re: type of barcode scanner
There are so many barcode scanner products. Most of them needs to be connected to a device such as a PC for live readouts. What you are looking for is an offline barcode scanner where it could buffer records and flush to a PC when connected. These could be little expensive than the online type. You may google for products.
