An error with a comboTV box & a monitor
Post by Rksk » Wed May 04, 2011 4:07 pm
There is a comboTV box & a Dell monitor. When they plugged & powered, the monitor says "monitor is in powersave mode, activate using pc" in black background.
But the comboTv box works fine with another LG monitor. Also the Dell monitor works fine with the PC.
Where can be the problem? Have any idea?
Re: An error with a comboTV box & a monitor
Post by Nipuna » Wed May 04, 2011 4:43 pm
Try this
http://www.ehow.com/how_5004034_dell-mo ... -mode.html
I just Googled it and Found i don't know will it work or Not :)
Post by Rksk » Wed May 04, 2011 4:57 pm
But the monitor doesn't turn on correctly with the combo box in any way.
thankz for ur reply friend.
Post by Neo » Thu May 05, 2011 12:00 am
If you have a menu on the monitor, find reset menu and do it. It might fix your problem. If you don't have such an option, then you would probably have to go for a different monitor.
