How to Remove shadows of Satellite TV
How to Remove shadows of Satellite TV. For some channels there are shadows.
Re: How to Remove shadows of Satellite TV
Call the company and their technical team will assist you. They tuned my unit after I report this and now I'm fine.
Did they charge you for that? if they did how much?Saman wrote:Call the company and their technical team will assist you. They tuned my unit after I report this and now I'm fine.
I deal with them in corporate level, so they didn't charge. But the technicians said they usually do so.
If you call the service line, you will get all the information required
Thanks. I'll TrySaman wrote:I deal with them in corporate level, so they didn't charge. But the technicians said they usually do so.
- angelabrookss
Normally the technicians do charge for this service.
Thanks for replies
have to admit , in all my life i really never ever heard about shadow in Satellite TVNipuna wrote:How to Remove shadows of Satellite TV. For some channels there are shadows.
Sri lankan Satellite TV Service is still hight quality ones.
They all are still poor quality and high fees
That's why this happens
I'm also in doubt why Nipuna is having such effects for Satellite TV.
1. What's the service you use? Is it Dialog TV?
2. How far is you from ground transmission station? (I'm sure you are not receiving satellite transmission directly as this is not yet available in Sri Lanka?).
3. If you are not using direct satellite reception (receiving signals from a ground transmission station), do you have much disturbances like mountains in your area?
If that is the case, why don't you simply switch to SLT PEO TV (IP TV). With that not only you get the crystal clear quality, you will be able to play your favourite missed programmes too.
