Now it is asking for the 5 digit security code right?.
If that is the case, there is a way to get the code from the phone's permanent memory. You can use NSS(Nemesis Service Suite) to read the appropriate PM field and get the code back. (I haven't tried this my self). Or flashing the phone with Nokia's own software pheonix will remedy the problem. Flashing with pheonix with easy, you can even flash dead phones(result from a bad flash) with it. Google for "Pheonix slayer" and you will get a result from blogsopt, get pheonix from there. Use "navifirm" to download the right version of the firmware for your mobile. After that flashing is a piece of cake.
When downloading the firmware, be sure that it is the same version or higher version as the phone's existing software. Otherwise it would lead to a dead phone due to security restrictions on BB5 platform.
By the way, is it just that you cannot use some other SIM other than the SIM that was in the phone by the time it was locked, or cannot use any SIM at all?
__________________________________________________________________________________________________
I copied the following guide from a web site, and be careful when giving your IMEI to any service offering free codes. They might be harvesting IMEI numbers so they can sell it to some one else. (Yes, this happens)
These newer BB5 phones require software to reset the security code:
Nokia 3250, Nokia 6125, Nokia 6131, Nokia 6270, Nokia 6280, Nokia 6630, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 7370, Nokia E50, Nokia E60, Nokia E61, Nokia E62, Nokia E70, Nokia N71, Nokia N72, Nokia N73, Nokia N80, Nokia N90, Nokia N91, Nokia N92, Nokia N93,
Nokia BB5 security code reset procedure:
Connect your phone via USB cable in pc mode & install the drivers for your cell phone provided with Nokia pc suite, then exit pc suite.
    Then install Nemesis service suite
    Select USB virtual drive during installation (in case of nokia 6120c)(for nokia 5700 use diamond protection)
    After installation open it
    Click on scan button
    Click on phone info
    Click on scan
    Click on permanent memory tab given on right bottom of application
    Click on read
    It will read the permanent memory file & write it to the disk
    Your pm file will be located in the path:
    C:\program files\nss\backup\pm\356252*********.pm
    Open that pm file in notepad
    Now scroll until field [308] and on the 5th record your security code is saved
    Look for something like 5=31313131310000000000
    Remove all the "3" digits and it will look like this:
    5= 11111 0000000000 now the first five digits is the code "11111".
    Note :- Use this at entirely your own risk, we cannot be held responsible for any phone damage or data loss on your phone or computer.
