Calling C/C++ function from ASM code
Post by Neo » Fri Oct 02, 2009 5:49 pm
Following steps need to be followed to call C/C++ functions from an ASM code.
  1. Compile C code and get the OBJ file
  2. Call the C/C++ function as .call _funcname(parameters)
    Example:
    			SWAP2		lastVal, reg1
    			SWAP4		reg1, reg1
    			.call		_write_to_disk(reg1)
    			ZERO		lastN
    			ZERO		lastVal
    			B			savelastVN						; Branch
    There are few things to notice here.
    • The C/C++ function is write_to_disk. But we have added '_' prefix. This usual as the compiler adds '_' to functions in the symbol table
    • Whenever we pass a parameter from ASM, we need to make sure the C/C++ function is ready accept the size of a register. For example: In a 32-bit system where registers are 32-bit, the C/C++ function prototype must be something like write_to_disk(int value)
NOTE 1 : If the function is called from inline assembly make sure you don't put the '_'
NOTE 2 : If it is x86 assembly, the calling function is 'call' without the dot (.) prefix.
Herath
Re: Calling C/C++ function from ASM code
Post by Herath » Tue Aug 10, 2010 10:17 pm
I have seen programs Pushing parameters in to the stack before calling a function. (While disassembling little executable files.) . I am taking about x86 assembly.
Post by Neo » Tue Aug 10, 2010 11:45 pm
In Intel x86 asm, call and return of functions handled using push/pop (stack) as you said. An example is given below.
__declspec(naked) unsigned long
SET_AA(unsigned long inputDWord )
    __asm
        mov eax, [esp+4]
        mov al, 0xAA
        ret               // final value is in eax
__declspec(naked) void
function(unsigned long inputDWord, unsigned long *outputDWord)
    _asm
    // you need a prolog/epilog to make C happy
    // here's the prolog:
    push ebp
    mov ebp, esp
    mov ebx, inputDWord    // the value you're going to change
    mov ecx, outputDWord   // address of where to put the result
    push ebx
    call SET_AA // puts the result in eax
    pop ebx
    // copy the result to the thing ecx points to (*outputDWord)
    mov [ecx], eax
    // epilog to keep C happy
    pop ebp
    ret
Herath
Post by Herath » Tue Aug 10, 2010 11:55 pm
Wow!. You seems to be great at asm. I like to learn that too. I know a bit. But I like to go further. There is no end to it!
Thank you for the explanation. I used to practice reverse engineering of software when I was home after A/Levels. I just had a memory of it. :)
