Another Tick Tack Toe Question!?
Trebor29
Re: Another Tick Tack Toe Question!?
Post by Trebor29 » Fri Dec 31, 2010 8:09 pm
You the man Neo! ;)
Happy New Year :P
Post by Neo » Sun Jan 02, 2011 12:12 am
Wish you the same and thanks for the complements :D
Trebor29
Post by Trebor29 » Sat Jan 08, 2011 5:59 pm
Hi Neo,
Sorry to be a pain, but I need some more help with the TickTackToe game... I know you love it really! :lol:
The problem I am having is calculating the winners on a diagonal, as it only recognises a diagonal win when on the center diagonals i.e. anywhere on the corner to corner(s)... nowhere else!
I have been looking through the code this morning but am going round in circles! :x
Ive just pasted the diagonal check code here, think ive already pasted the the rest previously. lol
 // diag check
                if (P == 0){
                   str1 = "";
                   str2 = "";
                   for (x = 0; x < N; x++){
                        str1 += tickTackButton[x, x].Text; // forward
                        str2 += tickTackButton[x, N - 1 - x].Text; // backward
                   if (str1.IndexOf(comb_X) != -1 || str2.IndexOf(comb_X) != -1)
                      P = 1;
                      PlayerWins(P);
                   else if (str1.IndexOf(comb_O) != -1 || str2.IndexOf(comb_O) != -1)
                      P = 2;
                      PlayerWins(P);
Post by Neo » Sun Jan 09, 2011 2:34 am
Had a quick look at that. I don't have much time today so you need to check this code.
  1. Define these new variables.
    int len_comb, N1;
    string str3, str4;
  2. Fine following code.
    comb_O = arr_comb_O[gridSizeComboBox.SelectedIndex];
    Add following code after that.
    len_comb = comb_X.Length;
  3. This code needs to come after the diagonal check code.
                // other cross dir check
                if (P == 0)
                    N1 = 1;
                    for (y = 1; y < N; y++)
                        for (x = N1; x < N; x++)
                            str1 += tickTackButton[x, x - N1].Text; // forward upper
                            str2 += tickTackButton[x - N1, x].Text; // forward lower
                            str3 += tickTackButton[x - N1, (N - 1) - x].Text;   // backward upper
                            str4 += tickTackButton[x, (N - 1) - (x - N1)].Text; // backward lower
                        if (str1.IndexOf(comb_X) != -1 || str2.IndexOf(comb_X) != -1 || str3.IndexOf(comb_X) != -1 || str4.IndexOf(comb_X) != -1)
                            P = 1;
                            PlayerWins(P);
                            break;
                        else if (str1.IndexOf(comb_O) != -1 || str2.IndexOf(comb_O) != -1 || str3.IndexOf(comb_O) != -1 || str4.IndexOf(comb_O) != -1)
                            P = 2;
                            PlayerWins(P);
                            break;
                        else
                            N1++;
                            if ((N - N1) < len_comb)
                            { // Not enough length to match
                                break;
Trebor29
Post by Trebor29 » Sun Jan 09, 2011 10:37 pm
Works sweat as a nut...! :P
I have been looking at Connect 4 source code trying to tackle it myself, but its very hard to try to unpick someone elses code, especially at my level!
When im working i'll have to put you on my pay roll.. :lol:
Thanks "again" Neo.
Post by Neo » Mon Jan 10, 2011 2:26 pm
You are welcome....
Always try to group things and find a combination. This is the way to simply coding...
