After My A/L I want to Learn Assembly For That Please Give me an Assembly Tutorial.
Assembly
Re: Assembly
First see https://robot.lk/viewtopic.php?f=12&t=1636. It's also one of your posts.
Assembly is the symbolic instruction set of the machine code. Machine code is the code of the microprocessor or microcontroller. So assembly language changes from CISC (Lot of instructions) to RISC(few instructions) and from processor to processor. You can't use assembly language of the x86 IBM PC on a Microchip PIC 16F877 microcontroller.
So you can just aim x86 IBM PC assembly for now I think. This one is good to start with. Some valuable information is also can be found here.
See x86 Complete Instruction Set at https://robot.lk/viewtopic.php?f=12&t=50
It seems that you have gathered so much things to learn which will take about 5 years after A/L.
Re: Assembly
Thanks. But I'll Try to learn them my best.
Re: Assembly
No need to repeat. Learn one thing at a time. We also have lots of fantasies. But no one is able to grab everything all at once. So make a plan to learn step by step. Learning small parts from each (without going in to advance topics on each) will make you a jack of all trades and a master of none.
Re: Assembly
Ok Thanks I willNeo wrote:No need to repeat. Learn one thing at a time. We also have lots of fantasies. But no one is able to grab everything all at once. So make a plan to learn step by step. Learning small parts from each (without going in to advance topics on each) will make you a jack of all trades and a master of none.
evangilbort
- Sergeant
Re: Assembly
Assembly language is a low level programming language. It is very strong between the correspondence language and architecture machine code instruction.
