Automatic management of memory
Java uses an automatic garbage collector to manage memory in the object lifecycle. The programmer determines when objects are created, and the Java runtime is responsible for recovering the memory once objects are no longer in use. Once no references to an object remain, the unreachable memory becomes eligible to be freed automatically by the garbage collector. Something similar to a memory leak may still occur if a programmer's code holds a reference to an object that is no longer needed, typically when objects that are no longer needed are stored in containers that are still in use. If methods for a nonexistent object are called, a "null pointer exception" is thrown.
One of the ideas behind Java's automatic memory management model is that programmers can be spared the burden of having to perform manual memory management. In some languages, memory for the creation of objects is implicitly allocated on the stack or explicitly allocated and deal located from the heap. In the latter case the responsibility of managing memory resides with the programmer. If the program does not deal locate an object, a memory leak occurs. If the program attempts to access or deal locate memory that has already been deal located, the result is undefined and difficult to predict, and the program is likely to become unstable and/or crash. This can be partially remedied by the use of smart pointers, but these add overhead and complexity. Note that garbage collection does not prevent "logical" memory leaks, i.e. those where the memory is still referenced but never used.
Garbage collection may happen at any time. Ideally, it will occur when a program is idle. It is guaranteed to be triggered if there is insufficient free memory on the heap to allocate a new object; this can cause a program to stall momentarily. Explicit memory management is not possible in Java.
Java does not support C/C++ style pointer arithmetic, where object addresses and unsigned integers (usually long integers) can be used interchangeably. This allows the garbage collector to relocate referenced objects and ensures type safety and security.
As in C++ and some other object-oriented languages, variables of Java's primitive data types are not objects. Values of primitive types are either stored directly in fields (for objects) or on the stack (for methods) rather than on the heap, as commonly true for objects (but see Escape analysis). This was a conscious decision by Java's designers for performance reasons. Because of this, Java was not considered to be a pure object-oriented programming language. However, as of Java 5.0, auto boxing enables programmers to proceed as if primitive types were instances of their wrapper class.
Java contains multiple types of garbage collectors. By default, Hotspot uses the Concurrent Mark Sweep collector, also known as the CMS Garbage Collector. However, there are also several other garbage collectors that can be used to manage the Heap. For 90% of applications in Java, the CMS Garbage Collector is good enough.
