Hi Nipuna,
The whole logic is here. I have added a parenthesis to the first 'for' loop for better understanding.
for(a=1; a < size; a++){
for(b=size-1; b >= a; b–-) {
if(nums[b-1] > nums[b]) { // if out of order
// exchange elements
t = nums[b-1];
nums[b-1] = nums[b];
nums[b] = t;
Okay... The first 'for' loop runs from 1 to (size - 1). That is, say you have 10 elements. The loop runs from 1 to 9. That is 1 less the total number of elements.
Now consider the second 'for' loop. It runs from (size - 1) to 'a' (the value given by first 'for' loop). For example, say the first 'for' loop runs 5 times, then the values of 'a' is 5. Then the second 'for' loop runs from 9 to 5 (5 times). Botice that second 'for' loop runs in decreasing order where as the first one on increasing.
Okay... Now let's see what is happening. As Sandun stated, we will have to write the values on a piece of paper for each iteration.
I'll run the first one. I'll assume there are 10 elements so 'size' = 10.
First 'for' loop runs from 1 to 9:
a = 1
Second 'for' loop runs from 9 to 1:
b = 9
if (nums[8] > nums[9]) { <- here we check the last element with one before the last element
// last element is lower than one before the last one -> we need to swap element 8 with 9
t = nums[8];
nums[8] = nums[9];
nums[9] = t;
b = 8
if (nums[7] > nums[8]) {
// 8th element is lower than7th one -> we need to swap element 7 with 8
t = nums[7];
nums[7] = nums[8];
nums[8] = t;
b = 1
if (nums[0] > nums[1]) {
// second element is lower than first one -> swap them
t = nums[0];
nums[0] = nums[1];
nums[1] = t;
First iteration of 1st loop done. Now 'a' become 2
a = 2
b goes from 9 to 2
On the 3rd iteration
a = 3
b goes from 9 to 3
On the last iteration of first loop,
a = 9
b goes from 9 to 9 (So will run only 1 time to check 8th element with 9th one)
So the simple logic here is to get the lowest element to top on the first run second loop.
On the second run of second loop, it takes the 2nd highest element to 2nd position of the array.
Likewise on the last run it adjusts the last two elements on the array by taking the lowest one to top.
So the lowest element comes up just as a bubble in water.
Hope you have a better idea now.
